I see you
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Brew Master
I don't know about screwdriver heads but I need you to come organize my shop!
Nick |
I'm going to add one more thing, that points out two different aspects to this discussion. One, there are surface finishes and treatments that some bits have that help prevent cam-out. Two, take a note in the difference of the angles and radii on these four bits. There is less standardization in the shape of a bit then there should be. The same can be said for screws, some are vastly better formed than others. I tend to buy all of my fasteners at supply houses , I never buy the (China) junk they sell in the box stores and general hardware stores. For existing screws, I always check the fit of the bit in the screw before using it.
https://www.finehomebuilding.com/2007/11/06/whats-the-difference-phillips-head-screwdriver-bits |
As an added tip: For particularly difficult screws valve grinding paste on the bit helps.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Fleabit peanut monkey
Just learned this two weeks ago the hard way by gouging out two Pozi drive heads on a idle air control valve on an old Camry with a phillips driver. Did not Google task prior which produced many read flags re type of head.
In fairness they were already beat on. What's funny is I looked through my stash of driver bits and had about eight of the Pozi drive bits. Just never knew.
1981 911SC Targa Last edited by Bob Kontak; 11-28-2018 at 07:26 AM.. |
1986 Bosch Icon Wipers coupe. |
You thinking it wasn't a pozi drive and was JIS since screws I bunged up were on a Tay-ota?
Sounds plausible.
1981 911SC Targa |
Look for the little dot next to the recess on the head, that usually identifies it as a JIS screw
Almost Banned Once
I thought of this thread when I watched this video... Milwaukee Shockwave gets tested.
Way more info than most normal people would care about but perfect for a tool geek like me.
- Peter |
After going through 3 pages of a 2 year old thread, I ASSUMED that there would be a spammer at the bottom who bumped it, to tell us in some secret spammer way about his company that makes screwdrivers.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Almost Banned Once
I read this thread years ago and then I remember it whilst watching a video... but I can't remember someones name 10 seconds after they tell me the first time.
- Peter |
I watch his stuff too, right after Rick Beato.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
AutoBahned
PB Swiss seems to have a bit design that works well
but Phillips Sux |
I really like the Snap-on Phillips bits and screwdrivers.
Also am fond of something called P2R it’s a Phillips with a slight bulg or something that seems to work much nicer.
Rutager West 1977 911S Targa Chocolate Brown |
I've been using Makita bits for 30 yrs and... they just work. Set the clutch right for the job and drive screws all day. For mass production on wood decks or fences the square drive is a good alternative if a Phillips makes you crazy.
2021 Cayman GTS 4.0L 2020 Macan (dog hauler) |
