Scooping up a gravel driveway...
What's the best tool to rent...besides a shovel
![]() I KNOW Cabman would sell me sumthin' ...he's a B$'er ![]() Thanks! |
Brew Master
Come on man! You know the answer is a skid steer loader. Rent a track machine because they tend to stay on a true path without the bucket dipping due to the flex in the tires as you load the bucket. There's a feature a lot of people don't know about called "float". This allows the boom to travel with the contour. Set the boom in float and tilt or curl the bucket to increase or decrease the cut if necessary.
Nick |
I've never used anything like that...I figured that was the answer...I'll see who rents them locally. How efficient....with a noob...can I scoop up say 50' of driveway in a few hours....or daze....if I'm lazee? I'd have to rent a trailer too...
Skid Steers are very easy to operate, especially Bobcats. I have a "79" model that still works strong.
72 911 coupe 2.7L S Cams/Webers Street/Track 68 912 coupe 1.6L sold |
Bobcat. Plus they are fun to operate.
Listen to Cab - he knows!
Very easy learning curve if you don't hurry. Learn to use the bucket backwards to level and smooth. https://www.skidsteersolutions.com/video/ https://duckduckgo.com/?q=skid+steer+videos&t=ffsb&atb=v110-1&ia=videos&iax=videos&iai=6crRApG1RAo
1996 FJ80. |
Brew Master
With the T750 I have here, I could do 50 feet in about 30 minutes if all I'm doing is cutting and dumping into a trailer or different location. But I also have an eight foot wide bucket on the machine. You'll probably rent something in the 60 hp range and that'll still get the job done quickly once you get the hang of it. Ask the rental person to show you how to use float. It'll keep you from cutting too deep as if the driveway has any dips in it.
Nick |
I hate this place...I ask a simple question, and I'll end up owning a Bobcat
![]() Now I ain't sayin' I won't, but for this task....mebbe I should just hire someone? They'd be done in the time it took me to transport, etc. |
You can rent one for a day for a couple hundred bucks. Simple to operate. A blast to drive.
Brew Master
Something else float is nice for, back dragging once you've done a cut. On most joystick machines there is a float button (unless it's a Takeuchi or a Kubota they have hydraulic joystick controls) all you do is push the right handle full forward then press the float button to lock the boom in float. As long as you don't pull back on the right joystick, the boom will stay in float. So when you're back dragging, you put the boom in float, roll the tip of the bucket down as though you're trying to raise the front of the machine then start backing up. This allows the boom to move with the contour of the driveway and you're just using your right wrist to dump or curl the bucket to level the stone. I know it sounds hard but once you're in the machine you'll get the feel for it.
Nick |
Brew Master
If you're not in a hurry and just want to play around, rent one and do it yourself. They're fun to run. Just make sure to tell anyone that might approach you to do so from the front of the machine. Rear visibility it terrible on just about every machine out there. Just be careful. You don't want anyone getting hurt.
Nick |
FUSHIGI
Since we're all here to help, I would recommend the Cat 257D. Just say'n!
Cults require delusions. |
Information Overloader
![]() Quote:
You’ll be amazed at how you survived so long without one. Lots of neat attachments! Cheap, too! |
Thank you all...Ima gonna call "the guy" for this one. I'm going to get rid of that section...gravel going all the way to a busy, dangerous, street....no place to learn. But on my other property...well, a John Deere tractor has that covered....dayum. I'll find an excuse...
Sissy
You misspeeled Lazee
![]() Nope...I pass by a "Bobcat work" sign....good ol' county boy rates I'm sure....might be a Franklin...no schit. If I can rent one (& trailer) for a day at no hassle, and reasonable...I'd do that. Flat smooth drive, tires, I can do near the road ahead of time....and as good of an excuse as any ![]() Thanks all! |
MAGA
While not the ideal tool, I was able to use my JD 2305 compact tractor with loader bucket to dig out sod and then replace with 40 ton of stone when I added to my shop drive a couple months ago. The sod was difficult to dig out and I had about a 50 yard trip to my dirt pile out back to get rid of each small bucket load of sod. Took forever to remove the sod (a whole day digging) but got the job done.
B4 ![]() ![]() After ![]() ![]()
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
KC around here " the guy " generally charges a 4 hour minimum for most heavy equipment , may be different by you . I've never run a Bobcat in my life but a few months ago had a chance to use one . I had the basics down in 10 minutes . In the fall I am going to attempt to clear a 24 ' x 28 ' piece of grassy area on my property for another garage . I'm going to do it with a John Deere 332 diesel garden tractor with a loader and tooth bar . I know it will be slow but all I have to do is cut/drag/scoop the existing grass and then back fill with gravel . Good luck
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Most people would use a tractor equipped with a box blade for this task, a bobcat is nowhere near the the top of the list for road grading.
A bobcat is may be something that seems like fun, if you’ve never run any equipment in your entire life, but it’s about the last piece of equipment that some of us would buy. Hell, even a backhoe could knock this out in half the time it would take a bobcat. |
Thread Tools | |
Rate This Thread | |
