Doing a web series on my low buck 911 Project, looking for feedback
Episode 1: Project Overview
https://www.youtube.com/watch?v=QQ_jFiTON2g Episode 2: Dropping the Engine/Trans, How To / Walk Through the entire process! https://youtu.be/W870A-EizDE Episode 3: Checking Head Studs https://www.youtube.com/watch?v=-0gUImuE5e0 Episode 4: Leak Down Test https://www.youtube.com/watch?v=PUn1QOK5vDg Really just looking for feedback, but I'll be updating this post with more episodes as they come out. I did a similar thing last year with an overlanding build of an AWD Astro, turned out pretty decent: https://www.youtube.com/playlist?list=PLuUnOD-P-8CHad5AXxZ4_BiC1LK4s19x8 Would dig any feedback or suggestions you have, thanks!
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com Last edited by ADDvanced; 05-05-2020 at 01:09 PM.. |
Fleabit peanut monkey
I would not short change a 2.7 refurbish.
As you stated magnesium is soft. Some important German guy a while ago said they flex like a banana. The video is so well edited. You have skills. My suggestion is to work hard and eat the labor cost with your own skills and pay the extry for all that stuff you are supposed to do for the 2.7. Bruce Anderson said it's a great engine once the cooties are tended to.
1981 911SC Targa |
Love the concept. Had to stop watching at around 0:46. I can't handle the camera work. I got motion sickness.
Ha. Well. If it helps the hyperlapse stops at 0:55 and doesn't happen again.
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
I enjoyed that, please continue.
Perhaps emphasise again & again that cost savings can be achieved, to some extent, with a 2.7 rebuild (& a 915 refresh). Good luck. |
You should do the leakdown test before deciding to tear the motor apart. Do it several times in fact.
A SC is 3.0 liters, not 3.2. A 3.2 Carrera with Motronic would be beyond your budget with just the necessary fuel/ wiring alone. Fixing the oil leaks are the easiest part of this project. Most likely just oil return tubes and thermostat. You will have to drop the engine to get to the thermostat. The thing to do is clean the entire engine thoroughly, then run it to see where fresh oil leaks out. |
Nice video. If you want to make $$$$ they need to be longer. Between 10 and 20 minutes. If you are going to have fun doing this, you may as well make some cash.
Keep talking, Im gonna put you in the trunk. |
You need 10,000 subscribers to make a single cent. I have 300, so.... it doesn't really matter. Lol. Next one will be longer though, as it covers the entire engine/trans removal.
+1. I didn't get sick, but you need to slow down the panning.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
https://www.youtube.com/account_monetization?nv=1
1986 Bosch Icon Wipers coupe. |
Ignore the people discussing money.
They are missing the point. You will not make a dime. Keep up the video documentation. It is nonexistent on these cars
Everybody on youtube started with a first view. You do quality work. Promote it on a few forums and before you know it, it could get big.
I liked it. Looking forward to more.
Ignore Sugarwood. I know people who make some money. I don't know any YT rock stars.
To make money on YT you play the game their way, not yours. |
Leak down test on a stone-cold motor out of the car?
Okay here's what I would do if you were my friend that I knew you. I would help you change the oil pressure switch and the thermostat o-ring for the in block thermostat. Adjust valves. Look for obvious vacuum leaks. Reinstall engine. New engine oil and filter. Clean the engine oil off the outside of the engine and the bottom. Check to see where clean engine oil is leaking out. You may have a leak at the oil cooler, in which case it would be the oil cooler o-rings. at this point you need to check fuel pressure, ignition timing, and ideally borrow or buy a wideband O2 sensor to check your mixture ratio.
Ignore me? You are the one posting lies.
To monetize, you need 1000 subscribers. PERIOD. Look at you giving out tech advice, LMAO.
Good video!
I thought the editing, content and overall duration is good - I just subscribed as well. I have transitioned most of my technical "how-to" videos on YouTube as I own a bunch of old cars and like to help other owners. I have just under 900 subscribers and my video with the most views actually has over 77,000 views and I received a royalty check from YouTube for less than a $1.00, which I framed ..haha! I actually started doing YouTube videos back in early 2006 and had decent success and then dropped completely off for 6-7 years due to "life" and then slowly started rebuilding my channel and content as many people kept asking for more and why did I disappear. Looking forward to updates on your Targa. Keep it up. Yasin
Ole Skool - wouldn't have it any other way |
The point is, there are many ways to skin the cat. The 2 figures of 1000 and 4000 are part of a bigger picture. That's all I'm saying and you're saying meet those 2 requirements and the money rolls in (trickles). I'm saying I disagree. And yes, I met my tech fu match with video work. It's a totally alien world to me. I'm proficient in MS PP, Publisher, Paint, Adobe PS, Sketchup and many other apps. Silly me to think I could jump right over into the dynamics of videos and editing software. |
