Its a track/street car. I bought an unfinished project. I had the interior done and painted the car. Its a freshly rebuilt engine and short geared transmission (came with the purchased with built specs). I have to do some digging because there's a loose wire that keeps the gauges from working 100% of the time.
On my car (1975) the "B" light is on for both parking brake and there is a switch on the master cylinder to show a fault in the braking system. You can see the switch on the master cylinder here:
https://www.pelicanparts.com/More_Info/91135501202.htm?pn=911-355-012-02-M253&SVSVSI=5871&DID=3564
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Navin Johnson
Sorry guys
I sure wish there was a forum, or sub-forum on this site, where I could find an answer to this question..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
That is the parking brake light. The one at the bottom of the gauge is for the alternator.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Looked and did some digging this morning. No wire from parking brake. Its been yanked out, only the handle is mounted there to keep the open hole shut. Corner balanced and aligned at 2214 lbs with 12 gal of fuel. I am puzzled how this light is lit up without any wired from the parking brake area?
Pretty easy to swap a wire on the back of those gauges. Does the alt light come on? Are the gauge illumination lights on?
see above - on some MYs it also is a warning re the brake fluid in the reservoir
check it - that switch might fail so the light never comes on, but you need to run it down again as above, on some MYs the light tells you about the alt. or the VR - there is also an upgrade re putting a resistor in the circuit form some MYs Last edited by thor66; 04-02-2021 at 04:34 PM.. |
I never noticed the alt light come on before. never turned on the lights so will check. It just sat after all the work got done and the BLM riot started so I didn't want to chance it driving it around because I don't trust and don't know what's waiting for me at the off ramp. Now that I have some time, I am going to play with it a bit.
Good, but after 45 pico-secs. i realized it may fail to never light up
I see longhood but not your MY??
Bad ground wires and terminals on German cars makes lights do weird things. Disconnect the ground from the taillight housing and see what I mean. Voltage has to go somewhere.
Navin Johnson
I'm guessing the OP is asking about the illuminated large red light.. Which is the Alternator warning light, The bottom light in that gauge is the handbrake. Apologies, my printer/scanner recently went kaput and I haven't replaced it, so pics From a '71T manual which came with the S gauge package.. ![]()
Navin Johnson
And seriously isn't there a forum, or website where 911 specific question are asked?
My other ride is a C-130J
I think his gauge is different than the one in your ‘71 owners manual. If you look at his photo the top light has a B under it (handbrake/fluid) and the bottom light has a G (Generator).
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 04-02-2021 at 05:45 PM.. |
^ he's enforcing track limits, but on an on-line forum.
Here is a link from Pelican that answers his question.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/88-Speedo_Repl/88-Speedo_Repl.htm
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Navin Johnson
And even that link /picture doesn't match the picture the OP provided..
Who has eve seen a flickering brake warning light
AutoBahned
big red button light is likely Emerg. Flashers
toggle switch under dash says car has been messed with... intermittent light on while driving could be bad gnds, bad wire rubbing, of diodes failing in voltage regulator silver button gauge says longhood but does not say which year or if it is the right year gauge for the car... I know the tach electricals changed about '70/71 but not what else changed then - color wiring diagrams are on here somewhere, so the fix is just a matter of time & effort |
