My other ride is a C-130J
RNajarian's Avatar
Originally Posted by TimT View Post
And even that link /picture doesn't match the picture the OP provided..
Who has eve seen a flickering brake warning light
We don’t have all the information. What year vehicle are we even I’m not near my 911 or owners manual now. I know the solid red light under the B light indicates the handbrake is on.
My brake fluid has never gone low so I am not sure about this but PERHAPS the flickering brake warning light indicates low brake fluid level. . . or a ground issue.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-02-2021, 07:02 PM
Webb, its a 72. Oh yeah its been messed with. There's no wipers, no wiper motor and its basically stripped for weight reduction. The toggle switch is my fuel pump switch. A big Carter fuel pump mounted under the hood next to a just about two gallon oil tank.
Old 04-02-2021, 07:27 PM
Originally Posted by RNajarian View Post
Not sure if you are being facetious with this comment.
I think his gauge is different than the one in your ‘71 owners manual.
If you look at his photo the top light has a B under it (handbrake/fluid) and the bottom light has a G (Generator).
This, but Tim's photo of his book confuses me. E brake light shouldn't flicker or dim out.
Old 04-02-2021, 07:29 PM
AutoBahned
RWebb's Avatar
my '73.5 looks like yours
your brake light 'reads' the parking brake AND the brake fluid level I think
you may have to trace the wires, but turn the LF tire outward, crawl in with a rag & light and see if there is a wire going to the brake reservoir on the m/c
Old 04-02-2021, 07:57 PM
Send a message via AIM to fintstone
No, that is incorrect
I'm guessing the OP is asking about the illuminated large red light..
Which is the Alternator warning light,
The bottom light in that gauge is the handbrake.
Apologies, my printer/scanner recently went kaput and I haven't replaced it, so pics
From a '71T manual which came with the S gauge package..
That is not the gauge he has in his photo. The red light is clearly marked with the brake symbol and the bottom with the Gen (alternator symbol). I would guess his gauge is probably out of a '73 2.7
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-02-2021, 08:20 PM
maxnine11's Avatar
I'd be concerned about the zero oil pressure at 1425 rpm.
max
Old 04-02-2021, 09:06 PM
maxnine11's Avatar
max
Old 04-02-2021, 09:14 PM
Just checked, no light on all gauges. Tach is the only gauge that works. When I turn the keys, the red and green light lid up on the oil gauge. So there's power going to it. The little blue light next to 2000 rpm on the tach only lights up when key is on "Accessory" and goes off then I turn to on. I just discovered this blue light 5 min ago. Checked fuses, all are good. But will test with test light tomorrow. Jiggled wires behind and under dash and fuse box, all are good and connected. The fuel gauge doesn't work, or not connected. Need to pull it during daylight. I think there's power going to the gauges, but somehow it isn't lighting up or working. No clock btw.
Old 04-02-2021, 09:46 PM
Correction. The blue light next to the 2000 rpm mark only turns on when the light switch is pulled out half way to turn on side markers lights. So, I am getting power but no lights.
Old 04-02-2021, 10:08 PM
Here are couple more pics. If you guys see anything unusual, plesae let me known. Sorry for not putting this type of question over in Tech. I haven't post over there in many years so I didn't want to get chased out of there.
Looks like the speedo isn't connected at all.
Old 04-02-2021, 10:12 PM
RNajarian's Avatar
Unfortunately I do not have access to my car right now to check out my ‘75 owner’s manual, but look at the photo from this post.
http://forums.pelicanparts.com/porsche-911-technical-forum/1068665-1974-temp-specs.html
On the right of this photo you can see the manual is talking about the B light and you can see it says in the cut off photo it references a light that flashes.
Does anyone have this in their owner’s manual?
Old 04-03-2021, 06:55 AM
I was just about to post that. Strange nobody brought it up.
JUAN
'80SC Targa
Old 04-03-2021, 07:22 AM
The link I posted with the picture of the master cylinder with a brake light warning switch attached to it was from an early long hood - not from my MY 1975.
Take a look at your master cylinder and see if it has this switch. If so, disconnect the wire going to it and see if your light goes out.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-03-2021, 12:03 PM
when you say "no lights" do you mean the background illumination? There is a common wire for the illumination. If it shorts to ground, then you'll burn the entire wire and lose all background illumination in one go.
Old 04-03-2021, 02:38 PM
oh my. Yes, a lot is unusual. As for the wiring, you need a wiring diagram matching whichever year your gauges are "compatible" with. In other words, determine which MY you are going for, and you may need to graft onto the harness.
Old 04-03-2021, 02:41 PM
Yep. No background illumination. This is for all the gauges, no lights. What's the blue light next to the 2000 mark on the tach? Will tear into it later this evening and search for ground wire.
Thanks, will look.
Old 04-03-2021, 02:42 PM
The blue light indicate high beam headlights are on.
For what it's worth, the original guage illumination wire was blue/ black. It was sort of daisy-chained from one bulb to the next.
Old 04-03-2021, 02:43 PM
Cool. It would have taken me 3 hours with a test light to find that ground wire. I should just run another solid grounding wire and daisy chain them and be donw with it?
The blue light, high beam light comes on with a pull of the head light switch half way or the first click. There's some funking siht going on behind there I must sort out.
Old 04-03-2021, 02:53 PM
No, they ground against the guage. The single wire is positive.
Old 04-03-2021, 02:55 PM
