Originally Posted by rusnak View Post
No, they ground against the guage. The single wire is positive.
That looks like I must trace it back from fuse panel. This one is going to be a btich as I have not a clue which fuse to start?
Old 04-03-2021, 03:04 PM
there are a lot of threads on upgrading the lights to LED. The problem is that they are not dimmable, and also have bright/ dark spots.
http://forums.pelicanparts.com/porsche-911-technical-forum/802807-testing-some-instrument-led.html
Old 04-03-2021, 03:05 PM
Damn. My 911 is in storage. I'll see if I can find a wiring diagram.
Old 04-03-2021, 03:06 PM
It's better to restore the original wiring (using correct clorox and sizes) than to run a bunch of new wires.
See if you can get a date or other ID off of the back of that gauge.
Old 04-03-2021, 04:20 PM
also, you want to add some relays for the headlights to keep the bigly current from flowing thru the pull switch
Old 04-03-2021, 04:23 PM
Send a message via AIM to fintstone
Originally Posted by RNajarian View Post
Unfortunately I do not have access to my car right now to check out my ‘75 owner’s manual, but look at the photo from this post.
http://forums.pelicanparts.com/porsche-911-technical-forum/1068665-1974-temp-specs.html
On the right of this photo you can see the manual is talking about the B light and you can see it says in the cut off photo it references a light that flashes.
Does anyone have this in their owner’s manual?
The brake light blinks red when the parking brake is on in my My '74.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-03-2021, 04:46 PM
My other ride is a C-130J
RNajarian's Avatar
On my ‘75 it remains solid red
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-03-2021, 05:42 PM
Did that to my 930. I don't exactly like it even though I never dim them.
Old 04-03-2021, 06:29 PM
Thanks you guys. I am pulling the gauge after dinner.
Old 04-03-2021, 06:38 PM
