Charging Voltage Issue?
Hello again Pelicans.
I worry about things. However, when I see something change I figure there must be a reason. Case - 2006 Chevy Tahoe 160k miles or so... Volt meter on dash reading about 14 or just above since I owned the car. Recently it jumped up to 15 or maybe slightly above. I checked the voltage using a handheld meter at the battery and a digital meter that plugs into the cigarette lighter. They all seem to be reading close so I believe the 14->15v really is happening. The high reading doesn't happen until I've been driving for awhile. Then it stays high. Some times it drops to 13 or a bit lower and then goes back to 15 while driving. I got a new battery yesterday thinking it might be the battery. The issue is still happening. I went to my local Napa store and got the charging system "tested". Of course the volts didn't go up to 15v (only read 14.2) while the guy was testing so I didn't buy the new $230 alternator. I'm thinking of driving it for a few days to see what happens but I don't think the higher volts coming out is right. What do you think? Thanks, -Henry
Sold: 1989 3.2 coupe, 112k miles |
If I had to guess, I'd say it's an alternator issue, but that's just a guess.
The voltage regulator and alternator determine what is put out (VR internal to Alt 99% of the time). So if you're seeing too much power sometimes, then I'd expect that to be an issue with the VR/Alt combo.
If you have the time, just have your current alternator rebuilt by a local repair shop. Take it off, drop it at the shop, and ask for a non Chinese bearings, and a rebuild. It will be cheaper than a "refurbished" unit from the loacal parts store, and likely a better unit, not built in some factory where price and speed of the rebuild is the only things they care about.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
At this point - I agree. I'll probably get the new alt. and see what happens. The current alt. has 4 or 5 years on it so it could be due. I can't remember if I've replaced it before or not. I got the car with 100k miles. Thanks for the comment.
First off, I would want to see the actual voltage from the alternator measured with a good voltmeter. Your dash gauge is probably right, but I would want to see a proper confirmation before I did anything drastic.
If it's out of spec why not change the voltage regulator, or have a rebuilder do it?
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
My plan is to go to the rebuild place and see what they can do. I don't mind the cost I just want the regulation to be correct.
Your lighter outlet is all you need to check.
You need a new voltage regulator. It's probably easy to swap.
Check the connections to your alternator? It does sound like the regulator is acting up, with too high voltage you will end up boiling the water from your battery.
87 930, |
Update in case people want to know....
I took it to the rebuilding guy. He knew (thought he knew) exactly what it was wrong said the brushes were worn down too far. In a few minutes replaced the regulator module with brushes. I took it back home and installed. Voltage was still not stable. Readings to 15 volts and then reads 13.1 volts. Now he ordered a new alternator or might rebuild my old one. I'm not sure. One thing he said... The alternator is controlled to some degree by the computer and we hope that is not the issue. I hope that is not the issue. Stay tuned.
voltage regulator. are they now internal to the alternators?
poof! gone |
In most cars, they are internal and have been for a long time. There were some manufacturers that held out. I want to say maybe FoMoCo or Chrysler/Dodge had external VR for many years after most others had gone internal. It sounds like he swapped the internal VR and is still having the same issue.
Yes, No and now I'm not sure. Good question.
There is a "regulator" module on the back of the alternator. The "expert" explains that the "computer" controls the voltage or is somehow involved. Maybe someone can chime in and let us know. The application is huge - 2006 Tahoe 5.3 motor. This means there is a huge population out there with the same setup.
Looks like that model has a battery current sensor, you could try changing that, pretty cheap. All this added electronic crap to save a gallon of fuel every year.
87 930, |
The other comment he had is that one or more of the diodes are out or are intermittent.
This makes some sense as I watch the volts while driving. We should find out by the end of today.
I used to sell rebuild kits. I'd have thought that if he was going to tear into an alternator, that he'd replace the bearings, brushes, VR, and diodes.
Evil Genius
I wouldn't be all that worried at only 15 volts instead of 14.....
Life is a big ocean to swim in. Wag more, bark less.
Another thought I had.... The computer(s) in the car are very dependent on getting good clean power. It is a question - Should the computer be responsible for regulating the power?
Information Overloader
^^ On top of that, the voltage is out of control, so it could go higher.
