I'm confused as to how he could get 'two cars up'???
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
It fit perfectly (I went up there twice to measure) to fit over the joists and is held in place by two metal nailing plates for the joists. I saved the styrofoam cut and will fit it in before winter comes.
See the bent sheet metal under the tires?
There are four of them. The lift is being used 90* to how it would normally be used.
Scott '78 SC mit Sportomatic - Sold |
Brew Master
There's only one solution. You should give me the targa.
![]() BTW, front end looks like cast so I have no problems there. As long as you're using a back up support of some sort to prevent it from squishing you, I say go for it! Btw Btw... don't the decks come off those fairly easy? Why not just drop the deck, clean it, and put it back on?
Nick Last edited by cabmandone; 06-20-2025 at 06:25 PM.. |
I hope the nailing plates are at the ends of the 4x4.
^^^ My lift will rotate to anywhere I want...but it will not handle 'two cars up'
My garage is 26X40 so I have 4 stalls....my lift has been, at some time, in all 4 stalls.
The deck is not easy to get out after unhooking it. The front tires want to interfere. And then the weight of the deck makes tipping it over a chore without it wanting to roll away. As it lifts higher...I'm figuring I'll have more time to roll out. ![]() I'm thinking that this will save half the time and be a lot less work.
That's good to know on the nailing plates.
My brother's shop is 30x40, I think, it may be bigger. He proof loaded his lift when he got it by lifting his Turbo diesel Suburban when he got it. He's got an MS in Mechanical engineering and is pretty savy when it comes to making sure things are safe to use. He had the sheet metal 'rails' bent up by a local sheet metal shop. It took he and his son a little bit of work to get both cars up on them once they got the lift positioned in the shop. A case of where there's a will there's a way. My old 912 and a 911 are up top while his targa is down below and there might be a 914 there to now, I don't know for sure as I haven't been up to his place in a couple years now.
^^^ I'm seeing it now after you described it.....first I've ever seen/heard that.
Once I saw the linkage for the locking levers... I understood.
Information Overloader
I like Steve’s lift better than Scott’s.
Scott’s is the magnetized model for clutter and stuff. It’s probably good clutter but certainly not great clutter. |
^^^ I'll bet he does more serious work on his.
![]() Mine is/was used more for parking space...now that the SC is gone....I like the extra room.
It's not mine, it's my brother's lift.
He has a sickness. He says there is no cure but he keeps looking for one.
I would suggest removing the deck and then you could use your straps and hoist to hold it upright so you can do what you need to do. Do you have a lot of buildup to scrape out?
Does your deck have a wash port? My Craftsman LT2000 has a 46" deck. I can remove it fairly quickly because it has 3 quick-release mounting points. Sent from my SM-S916U using Tapatalk
"A little nonsense now and then is relished by the wisest men." Wonka |
My wash port doesn't work that good...might be because of the age of the deck. (22 years) Unfastening the deck is easy... getting it out is not. I mostly will use this for cleaning and removing the blades for sharpening. Since I started using this thing (in the link below)...I've been keeping them knife sharp and can really tell a difference in the cut lawn. https://forums.pelicanparts.com/off-topic-discussions/1178091-another-guess-tool.html .
Unfasten the deck then lift the tractor with your sling/hoist . Roll the deck forward from under the tractor . Flip the deck over and do your thing . When done roll the deck back under the tractor . Lower the tractor and make final connections . Done
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
^^^ As long as I have it raised, I might as well remove the blades and clean the deck.
At the end of the season, I always remove it and grease the spindles, and one last sharpen. Last fall, I found one of the decks idler pully was wobbling...so I put a new one on. I'll be trying it today, the grass is long because of two inches of rain in the last three days.
Kantry Member
Steve, absolutely no problem with the front axle pivot on your JD. You could hang the darned thing from the front axle and not have a worry. 650 lbs? That's nothing. The weak points are, as mentioned above: possible chafing where the straps attach to the cast axle,(easily addressed with pads) and your 4x4 distributing the weight over the base of four trusses. I would think about sistering those trusses or perhaps full gussets at the load point.
Best Les My train of thought has been replaced by a bumper car. |
Thanks....I'm thinking of buying an in-line scale (like a fish scale) to see exactly what weight I'm lifting. I'm thinking if the trusses held me squatting on one point, they should be good for 3X my weight over four trusses. I had thought of doing this years ago, but recently saw a YT video of a small engine repairman doing the same with my exact JD model....he was lifting his to a straight up/down position for replacing the hydro belt. That belt is tucked up under the frame and the tension spring looks to be fun. It's prob safer in a straight up/down position...all the weight is on the back wheels. something like this....goes up to 660 lbs. and is $30
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 06-21-2025 at 04:47 AM.. |
Fleabit peanut monkey
One of my casual lady customers has a Husky 2/3 the size of Steve's. She messed all of her belts up because grass accumulated. A buddy of mine had the same mower and he pulled her deck off, cleaned it and repositioned the belts in her driveway. Under an hour but he is just a little over 40 years old. I'm 68 and said many times while watching, I ain't doing this without two peeps. I did have to help him by holding this or that while he put it in place. You met him at my house - motorcycle guy that brought food in a box and ate it in front of us. However we were sipping on lager in front of his 12 years sober self.
1981 911SC Targa |
