What?!?!
Here's what mine looks like. That's where the front axles get pinned in. Can anything in there fail causing the slipping? I've driven the car like it is for at least 50 miles, 30 of that was on the freeway at 65mph with no odd sounds or vibrations. Strangest symptom is the MPH following the RPM when slipping with no change in actual speed.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
From what I looked at, the speed sensor is located near the rear of the transmission, so likely spinning correctly there. The output flange is likely attached by a spline, usually very strong and more likely to break the shaft. Trying to turn each rear wheel while transmission in 1st should point to the problem.
87 930, |
What?!?!
The car did it for me. ![]() And admittedly, I didn't check the rear closely enough. I just looked while under the middle of the car to see they were there. After all, I never touched that. How could that be the problem? Quote:
Ordering axles tonight. Ya'll rock! But I owe 908/930 a coupla beers. He told me three times.
What?!?!
Good to hear you found the problem, and easier fix then clutch. Not sure if you need new half shafts do the joints feel ok? It is strange that they are able to pop out.
87 930, |
What?!?!
They are original and have 335,000 miles.
They’ve certainly earned a retirement. |
Going back to post #1 it seems Subiworx missed it too.
What?!?!
I only had them install the cable. I didn’t ask them to fix it if it wasn’t the cable.
They didn’t do anything wrong. I should’ve made that clear.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross Last edited by DonDavis; 01-19-2026 at 11:33 AM.. Reason: wrong emoji |
Glad you got it fixed.
The weirdest clutch problem I ever encountered also turned out not to be a clutch problem. Triumph Spitfire clutch would not disengage. Long story short, the crankshaft thrust bearing was gone. Gone as in not there anymore. Probably in many past oil filters.
