The Unsettler
Hail Damage to roof
Was in NY/NJ for a bunch of days. Just got back today.
Monday night we had a monster storm come thru. My DD's which sit outside look like golfballs. Lots of damage in my development though my area seems not to have suffered the worst. The roofers have descended on the area like vultures. The neighbors I've had a chance to speak with have had multiple inspections/quotes and are all hearing the same thing, we need new roofs. Now I'm not a roofer but from the ground mine looks fine to me. Is hail damage something that you need experience to detect? What do you look for? If my homeowners covers it do I really care? Thoughts?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Cars & Coffee Killer
You might not see it from the ground, but it should be obvious if you are on the roof. You should see things like holes in shingles, missing parts of shingles, or whole missing shingles. If you have anything more than very minor damage, it's pretty much pay your deductible and get a new roof. It's generally not worth it for insurers to dick around with payment while more damage (more losses) occur due to leaks.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
They just delivered our new shingles yesterday.
We had massive hail damage from a storm in April. In our case, damage to the roof (5 years old) was obvious. Not only were the shingles visibly damaged, but I had to sweep large amounts of "gravel" that came off of the shingles that was all over my driveway, deck, etc. The edges of my shingles where they hang over the eaves (and into the gutters essentially) were bent and broken, chunks missing, etc.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Take a look for yourself, don't trust the contractors' opinion. Lots of scammers follow the storms for hail, tornados, etc.
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
Your roof may be fine for now. Hail can knock the sand coating off the shingles and damage the structure, shortening their life, but not causing leaks. Your roof may not leak, but if it was designed to last 20 years, it may only have the strength of a 10 or 15 year roof after the hail.
It's common around here to get storm damage estimates right after the storm, which are always high because roofers have more work than they can get done. (One told me he is 5 weeks out on estimates and months out on the actual work) Take the money the insurance company gives you based on these estimates and wait a year or two - wait until roofers are begging for work. Then get it done for less than half. This assumes that you have inspected the roof and there aren't any actual holes and it will last two years. For example, last fall I got an estimate of $250 a square to do my roof. A couple of weeks ago my friend got two estimates for her hail damaged roof of $1000 and $950 a square. This fall or next fall she'll probably get it done for $250 or so.
The Unsettler
The Unsettler
And that is after another storm came in two nights after the hail so wonder how much washed away.
The Unsettler
Calling my agent today to get things rolling.
Senior Member
Make sure you check the A/C units for damage. Then the chimney and vents on the roof.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Guest
Posts: n/a
Scott - if you don't get it replaced, you may get dinged when you sell the house. Make absolutely sure the contractor strips off the old roof (no overlay) and their contract includes a thorough clean up. I would go so far as to make them lay tarps around the perimeter of the house to catch nails/staples/debris. Some of these guys are really shaky, so call on long time established roofers in your area.
We had hail and a tornado 2 weeks ago. The hail was honestly the size of baseballs. Anyway, it totaled my X5, 330i, Roof, siding, outside lights, garage door, AC unit, gutters, front door, mailbox, hot tub cover etc. My roof was/is 3 years old. I have been on the roof and I dont have holes but you can feel the dents and we also have the gravel in the gutters etc.
Luckily we dont have any leaks but I can tell you that the shingles are no where as good as they were. On mine you can see and feel where the hail has broken the substraight on the shingles. I am going to try and hold off on replacing the roof until it slows down here. Like Stomach Monkey said, we have contractors everywhere and many people have put signs on the door telling people to stay away. That said, it has been a pain dealing with the ins company regarding the house but the cars were a piece of cake.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
You do not have permissi
As for damage to the girlfriends DD: I recently tried my hand at paintless dent removal. The following is the result of a hurried 15-20 minute effort:
Obviously the fix would not pass concours muster, but it was a good start. Then...afterwards...cough...um...I did an internet search and found the dry ice/hairdryer-and-duster technique: Remove Car Dents Quickly and Cheaply | Wise Bread. Have yet to try this proceedure. I think that a hot day would be best for keeping flexibility in the paint, and applying the dry ice on the backside of the metal would effect a better result. (Disclaimer: I have no experience with the above proceedure or characteristics of the forementioned materials.) Last edited by john70t; 06-23-2011 at 08:47 AM.. |
The Unsettler
Had a vulture stop by yesterday noon just after I got back. Seems to be from larg outfit, very professional, not pushy at all, left a big packet of information including copies of all their certificates, insurance/liability cards, references etc.... Only thing he pushed was that they are primarily a roofing company but also do a lot GC work so they generally find other things that typical roofers overlook, fence, A/C, facade damage etc... Said he'd only do an inspection in the presence of our adjuster so any "negotiations" are taken care of on the spot. I'll let him quote it along with a couple of others. What a pain in the ass.
Run smooth, run fast
What you want is a solid, local roofing contractor who has the GAF Master Elite Factory Certification. These contractors will not be much more expensive than others in the area, and will be making sure all your flashing, etc. is done to the highest level of quality.
They don't screw around with cutting corners anywhere because once they earn that Factory Elite certification, they don't want to lose it. Here's the website of the contractor that did our reroof a few years ago... nothing flashy as far as sites go, but informational. He came highly recommended and was top notch. Explained everything and answered all my questions. Burgin Roofing GAF website... lots of info there and you can punch in your zipcode and find certified contractors in your area: GAF Materials Corporation | Roofing No, I don't own stock in GAF, I was just very impressed by this guy.
- John "We had a band powerful enough to turn goat piss into gasoline." |
Oh yeah... how about a shingle that will stay on in winds up to 130 MPH?
GAF Roofing The GAF Certified installer has to use a specified number of nails in each shingle... I forget how many that is. Seems like it is six.
Targa, Panamera Turbo
StoMo - woke up at 2:30 AM that day to the sound of hail. Ripped up my Magnolias, pool was a mess. The roof prolly needs to be replaced according to 'roofing standards'.
I thought for sure our windows were gonna shatter. It was bad.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
B58/732
Funny how neither of our DDs had hail damage. Maybe it was because we never got any hail. Even funnier was how she insisted we still had hail damage after I told her this. When I tired of the conversation I started the lawn tractor up again and blasted her with dust and grass clippings. Most satisfying.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
The Unsettler
Some of the damage is weird, my house seems ok but two houses over the fences are just gone. The 4x4 support posts were not pulled out of the ground, they were snapped like twigs and the kids wood playset is just a pile of debris while the house in between us, their playset is untouched. Makes me think there may have been some small twisters along with everything else.
My friend got her check from the insurance company Friday. It was made out jointly to her and her mortage company. The mortgage company is insisting that she get the roof replaced within two years. They are keeping the money until she does. I'm not sure who keeps the overage or pays the shortage if the final bill does not equal the insurance pay-out.
I assume the mortgage company considers itself co-owner of the house and they don't think the owner/occupant is as concerned about it's condition and future value of it as they are. She's ticked off that she's poured tens of thousands into this fixer-upper making it worth far more that it was when they gave her the mortgage. What ticks her off more, and I understand completely, is that the insurance company and the mortgage company agreed on the amount of the damage claim and never consulted her about it. She simply got the check and a notice saying sign the check and send it to the mortgage company so they can co-sign it and keep it. I've had mortgages for over 40 years and had half a dozen claims, but I've never encountered anything like this.
. Last edited by wdfifteen; 06-25-2011 at 02:03 PM.. |
