Is there a distributor on this thing?
Some electronic substitution going on? http://forums.pelicanparts.com/porsche-911-technical-forum/788460-new-here-78-sc-cab-staying-family.html#post7821572 http://forums.pelicanparts.com/uploa...1370043991.jpg |
It works very well. My VR6 golf has a similar system. |
If anyone has the time could they provide a link? The original poster of that engine does not have it in his "garage" profile either. |
It's an older electromotive setup. |
Those are GM DIS style coils. Extremely common with aftermarket ECU due to quality, availability and performance.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/683469-question-coilpack-conversion-electromotive-hpv-1-a-2.html
http://forums.pelicanparts.com/uploa...1342769932.jpg 911 Coil mounting platform - on engine dual plug [1001-51] - $109.50 : Clewett Engineering, The complete solution for ignition & fuel injection http://www.clewett.com/images/1001-51ins.jpg http://forums.pelicanparts.com/porsche-911-technical-forum/676385-msd-ignition-exposed-6.html http://forums.pelicanparts.com/uploa...1336744382.jpg http://forums.pelicanparts.com/porsche-911-technical-forum/642917-bmw-direct-ignition-coils-911-a.html http://forums.pelicanparts.com/uploa...1323190337.jpg http://forums.pelicanparts.com/uploa...1323142077.jpg For sale: 1974 Porsche 911 Carrera RS Replica http://cdn05.motorsportretro.com/wp-...014AD2C2C0.jpg Clewett Engineering Catalog: Engine Management Systems http://www.clewett.com/products/engnmgmt/tb1.jpg |
Best looking pump I ever saw - seems they're usually black: http://forums.pelicanparts.com/uploa...1392237905.jpg |
G60 would easily fit... which means a 20v turbo fits as well. Such great engines off the shelf from VW during this time. Lower the compression with a spacer, add ARP head studs and a cam and it's 700hp capable with boost. Swap pistons and rods and you're north of 1000hp capable. Unreal.
| All times are GMT -8. The time now is 06:26 AM. |
