ckissick's Avatar
My 550 Spyder engine.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 08-25-2018, 11:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1781 (permalink)
madcorgi
Guest
Posts: n/a
I'm a big fan of this gem. Have one in my E92M3.
Four liter V8, 8200 redline.
Old 08-25-2018, 01:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1782 (permalink)
wdfifteen's Avatar
WOW. Gorgeous 32 PBIC engine. I have some of the parts to build one, but it’ll never get done.
Old 08-25-2018, 06:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1783 (permalink)
ckissick's Avatar
Got mine done recently.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 08-25-2018, 10:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1784 (permalink)
Leadfoot Geezer
rcooled's Avatar
A little engine porn from this year's Monterey Car Week
Duesenberg DOHC straight-eight
Tucker flat-six
Cadillac V16
NSU 4-rotor Wankle rotary (rear-mounted)
Old 08-26-2018, 12:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1785 (permalink)
A few I saw at the Carmel Street show this past week.
Scott
'78 SC mit Sportomatic - Sold
Old 08-26-2018, 02:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1786 (permalink)
pwd72s's Avatar
I was at a local car show...a local had ardun heads on a Mercury V-8. stuffed in an old T pickup. Foolishly, I asked the onwer what he'd do if he broke one. He replied: "I'd FIX it!" I'm sure he would...
Pic...now old, slow, and obsolete..
Old 08-26-2018, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1787 (permalink)
300hp 1800lbs is the goal
pksystems's Avatar
2.3L stroker 4G63.
Need to figure out my cooling issues. Huge aftermarket aluminum radiator with FAL slim fans overheated in no time. OEM rad/fan setup reinstalled. These fans won't fit in the cramped engine bay with the aftermarket rad.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 08-26-2018, 04:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1789 (permalink)
Old 08-26-2018, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1790 (permalink)
Every time I see one of these beauties I wonder why in the world, with all the then-high tech they employed way back then that they didn't make those engines more "breathable"? They were great engines - superlative for their times - and often blown. But the single, small diameter carbs etc always make me scratch my head.
(Perhaps I'm just showing my ignorance...)
1972 911T/S MFI Survivor
Old 08-28-2018, 11:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1791 (permalink)
Old 08-28-2018, 12:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1792 (permalink)
O.S. FR7-420 Sirius7 7-Cylinder Radial 4-Stroke Engine
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXZVB2
$3499.99
SPECIFICATIONS
Displacement: 0.6071cu in x 7 (9.95cc x 7)
Bore: 0.944" (24.0mm)
Stroke: 0.866" (22.0mm)
Practical RPM: 1,500 - 7,000
Weight: 111.7 oz (3,167g)
Crankshaft Size: UNF3/8-24
Distance from Backplate to Drive Washer: 6.2" (158.5mm)
Outer Edge of Backplate to Pushrod Covers: 4.8" (122mm)
Outer Diameter: 9" (230mm)
Carburetor Settings:
Needle valve, 2-1/2 turns open from closed position
Throttle Valve, approximately 1/4 turn open from closed position,
then start engine and follow break-in instructions on pages 19-25
in manual
jxs 06/24/10
ir/jxs
Video in link above.
You start it with your fingers, just like the little Cox engines.
https://www.osengines.com/engines-airplane/osmg1307/index.html
The impeller distributes balanced air-fuel mixture to each cylinder, which has realized long lasting stable idling.
Includes: 7 type F glow plugs, valve adjusting kit, radial mount & hardware kit, needle valve extension cable, glow plug cable set and aluminum case
Recommended props: 22x10, 22x11, 22x12, 23x8, 23x9, 23x10, 23x11, 23x12, 24x8, 24x9, 24x10, 24x11, 24x12, 26x8
http://www.supercheaphobbies.com.au/store/sirius-cylinder-radial-p-3685.html
Okay, now that's a way to start it that I can get behind.
Old 09-05-2018, 03:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1793 (permalink)
Old 09-05-2018, 04:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1794 (permalink)
Old 09-05-2018, 04:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1795 (permalink)
Old 09-05-2018, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1796 (permalink)
Old 09-05-2018, 04:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1797 (permalink)
Old 09-05-2018, 04:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1798 (permalink)
Zeke's Avatar
That's one of the coolest things I've ever seen. Beats Wayne's model flat six and that's something in itself.
Old 09-05-2018, 04:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1799 (permalink)
