Leadfoot Geezer
![]() Yes...that's a turbocharged flat-6 stuffed in there.
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '25 BMW 230i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects |
AutoBahned
Unregistered
This thread started out with people drooling how engines looked and that had nothing to do with how clean they were. It was all about how shiny and buffed out and painted and polished they were. Then you changed it to sloppy, then you changed it to CLEAN. Stick to one thought process. 90% of overhauling a piece of machinery is cleaning parts for inspection and reassembly. You can't rebuild something correctly if it isn't cleaned correctly. But there's a HUGE difference between clean and shiny. This thread isn't about cleaning an engine or it's parts, it's all about making them pretty, shiny, chromed or polished, painted, and otherwise buffed out. I appreciate pretty machines. The engine in my blown gas flatbottom was a supercharged chrysler hemi and everything on that engine was chromed, painted, or polished. Everything. Cost lots of money to get it that way. But there was no BS involved, I make it clear that I did all that JUST to make it pretty and none of that pretty had anything to do with how it ran (high 7's in the quarter). I could have painted it all flat black and it would have ran just as fast and just as long. I've been to your shop Henry and I appreciate how the engines you work on look. You know what you're doing but you don't have to treat me like an uninformed customer. I'm not. To pretend that they look all shined up because that's necessary to make em run good ain't gonna fly. They are shined up and prettied up to appeal to the senses, not to make them run better. There are allot of people out there who simply don't know any better and they think pretty and shiny means good. Motor meister can polish parts too, but I wouldn't let them touch my engine. It's a good business strategy to provide good AND pretty because that makes makes the customer happy, so there's nothing wrong with it unless they're told that pretty is necessary to make it run good. In the old drag racing days we had a saying, "if it don't go, chrome it". Oh, and anyone who rebuilds a 911 engine without installing seals on the rocker shafts is nutz (That should do it.)
FUSHIGI
IMHO, the thread title is Engine Porn...analogous to the visceral attraction to people porn. While some deviants may find seeing "sloppy" folks (or engines) desirable, the majority find them to be less so than "well kept" people (or engines). I can't see a thread titled "sloppy engines" going very far...but I could be wrong.
AutoBahned
is pornographic beauty skin deep? or is the underlying muscle and fascia important?
FUSHIGI
Beauty should be taken on the whole and have some slightly strange proportion to it (strong emphasis on the 'slightly').
Yeah, somebody fed that bulldog a whole buncha pretty... And made him LIKE it, too!
Crazy and stunning. The perfect image for this "engine porn" thread. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Max Sluiter
Volkswagen VR-6?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Try not, Do or Do not
In the last year and a half we have completed 4 RS light weight projects and three of our other projects were featured in Excellence magazine.
Of those customers not one would have believed that their project was completed properly had the cosmetics not matched the mechanical restoration. Those projects were not treated any differently than any other project we completed or are currently working on. Concourse restoration or stock street overhaul all get the same attention to detail. Why would any mechanic do any less? ![]() ![]() ![]() ![]() "Pride in workmanship" is part of our work ethic not a sales pitch. Quality shows.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 09-11-2011 at 07:09 AM.. |
Slippery Slopenose Victim
sxsman@hotmail.com Have guns , will travel Mr. Potato-head , 1974 911 Slant/turbo look 2.7 1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? ) |
![]() MTU diesel
1988 Carrera Coupe |
AutoBahned
anybody have a pic or link of that really small V-8 a Japanese co. built a couple/few years ago? might have been Mitsubishi...
SPECIFICATIONS H1V8: 75° odd fire V8 2.8 LITER, 170 cu. in. displacement (3.0 liter optional) 84mm Bore X 63mm Stroke (67 stroke optional) 4 cams, 32 valves via internal silent chain 530mm wide x 485mm long x 530mm high 400HP @ 10,000 rpm with stock street cams (higher spec. is available) 245 ft-lbs torque @ 7500 rpm 200 lbs engine weight Billet nitrided steel 180° crank 4340 H-beam con-rods with ARP bolts Billet 6061-T6 aluminum crankcase Dry sump 0il system with 4 stage pump 7.25" or 5.5" Twin disc clutch DTA S80 full sequential ECU ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
AutoBahned
Thanks, Henry
200 lbs. (!) |
Max Sluiter
There was a story in Racecar Engineering about a guy who owned a metalcasting company and was into UK speed hillclimbing and made the blocks for the twin Hyabusa V8. He was working on several variants for different classes, and also I think different bases like Honda or something more sporty than the Hyabusa. I believe that is what the Ariel Atom V8 is using.
Yes, it is the Atom engine (Hartley).
2012 Ariel Atom V8 500 - Top Speed "The V8 is actually derived from mating two Suzuki Hayabusa engines, featuring specifications usually reserved for the track rather than the road. They include a flat-plane crank, dry sump lubrication, forged internals, individual throttle bodies with sequential injection, and a 10,500RPM rev limit! All of this translates into 500HP and 284lbft at 7750RPM – staggering considering the size of the thing." But if 500hp is not enough... Jack Frost (Holeshot racing) assembled a mock turbo version of the engine. The small Garrett turbos shown are adaquate for 650 hp at mild boost levels.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Wow - 30 hrs between rebuilds. It must beat itself to death to get that hp/liter!!! Awesome!
David 1972 911T/S MFI Survivor |
