Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I luv how aero engines are built not to fail. Look at those fuel lines, wiring etc! Beautiful work.
- Peter |
Senior Member
Then become an aircraft mechanic! Its a lot of fun and nothing like fussing with airplanes all the time!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
David 1972 911T/S MFI Survivor |
Looks like a 908, but not the distributors. And wasn't the 908 an MFI?
Max Sluiter
Probably a type 753 or 771. The F1 engine. That had a flat fan but the 908 had a vertical fan. The F1 engine also used carbs at least initially.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
non-whiner
This one is in my GT40 that was featured in the Fast 5 movie:
"Too much is just enough." |
Senior Advisor
![]() the continental TSIO-550-C is a twin turbo/intercooled, injected, 6-cylinder, 550 cubic inch 310 hp engine weighing 420 lbs wet. I am an A&P and yes, it is fun but this model in a Cessna 350 means you have to remove both intercoolers to change plugs. Annuals are around 2-3K on this aircraft.
08 Cayenne Turbo |
Senior Member
Job security James... Try doing plugs on a twin or triple row radial engine then remember how that pays the bills at the end of the month!
