vash's Avatar
i need to cut a dog door into a fiberglass door.
wife's orders.
i've installed plenty of dog doors, but all into wood doors. what am i gonna find when i cut thru my fiberglass door? styrofoam core? this even going to work?
poof! gone
Old 12-19-2011, 08:51 AM
Parrothead member
VINMAN's Avatar
Usually they have a foam core. but I have seen some with a cardboard honeycomb core.
Vinny
Old 12-19-2011, 08:55 AM
canna change law physics
red-beard's Avatar
You need to re-think this idea. Dog goes outside, is wet/muddy, etc, and lets itself in. What could go wrong?
I would love a cat door, but I expect several of the neighborhood cats would move inside.
James
Red-beard for President, 2020
Old 12-19-2011, 09:00 AM
Super Moderator
cstreit's Avatar
Uh, you must have missed this part:
wife's orders.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-19-2011, 09:12 AM
vash's Avatar
i am against this idea..but yup. wife's orders.
we have an active racoon population..possums. i figured it is better to let her try, and when it goes sideways..buy another door.
poof! gone
Old 12-19-2011, 09:14 AM
Parrothead member
VINMAN's Avatar
I have one. Best thing I've ever done.
Vinny
Old 12-19-2011, 09:19 AM
mine's large enough for me to use..
scent of the dogs will keep the critters away...
Rika
Old 12-19-2011, 09:23 AM
Bollweevil
The first time she walks in on a racoon chowing down on the catfood, your marching orders will definitely be to replace the door.. exact same thing happened to a good friend.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 12-19-2011, 09:25 AM
Jim Bremner's Avatar
Tape the door with masking tape where you'll be cutting. Drill a hole use a fine tooth saw. If you're really anal have a spray bottle with water and keep the area misted to control dust. The end.
Old 12-19-2011, 09:32 AM
If you were closer I have a standard size exterior door I'd give you in trade for one with no dog door cut in it.
'87 924S (Sold)
Old 12-19-2011, 09:33 AM
Zeke's Avatar
There is no standard size door. Once it's hung, it's one of a kind.
Vash, get the door that you control the entry, exit functions.
Old 12-19-2011, 09:35 AM
What?!?!
DonDavis's Avatar
Get a second door and install the doggie door in that one and store your original door to reinstall when the wife changes her mind.
You know she will. Just sayin'.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 12-19-2011, 09:36 AM
wdfifteen's Avatar
You need to re-think this idea. Dog goes outside, is wet/muddy, etc, and lets itself in. What could go wrong? .
That's the big issue with my dog door. The floor in front of the door needs to be cleaned 3, 4 times a day unless we limit the use of the door. I've gotten to the point where I only allow access during certain hours.
A SawsAll should make whatever kind of hole you need in that door. You may need to reinforce it around the perimeter of the hole.
Old 12-19-2011, 10:16 AM
Platinum Member
dad911's Avatar
Can you put it into the wall next to the door?
Old 12-19-2011, 10:57 AM
300hp 1800lbs is the goal
pksystems's Avatar
haha... I put in a dog door for my <10lb Havanese cross. Very small door installed on a steel/aluminum screen door.
Middle of summer I let him out and went back to sleep. He came back inside and went to sleep. Hour or so later I hear a noise, but think nothing of it. Dog suddenly starts howling, and I hear the clicking sound of a dog walking across the floor.
One of the neighbours pitbulls has jumped the six foot fence, and squeezed himself through the small opening.
Luckily he was friendly.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 12-19-2011, 11:05 AM
You do not have permissi
john70t's Avatar
^This.
Buy one from the recycle place, a little paint, and use a cut-off wheel.
They make one-way dog doors with chimes/alarms also.
(They don't make wet 'n muddy dog sensors though.)
Old 12-19-2011, 11:56 AM
MAGA
Tim Hancock's Avatar
Our long haired dog is an outside dog.... The house would be full of hair, cat shiit, mud and stank if we allowed him inside. That said, I do let him sleep in the garage in the winter and I briefly considered installing a door for him to enter the garage.... Then one night he got sprayed by a skunk and I realized there is no way I want either a skunk or my dog after being sprayed by a skunk to enter at will into our semi finished garage.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 12-19-2011, 12:11 PM
john70t's Avatar
If there is space and a spigot near a door, you can make a dedicated wash-->drain pit area.
Good for boots and tools also.
Old 12-19-2011, 12:18 PM
madmmac's Avatar
A couple of battery operated remote controlled tabs on the inside part of the door and you can push a button and control what comes in when you want.
Or if you are not that lazy, just a manual slide. Dog can go out, but nothing can come back in till you release.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 12-19-2011, 12:27 PM
disband
juanbenae's Avatar
cliff, ive got a very good jigsaw that you can use. take the door off and work from a bench or saw horses. looking to hook up with you to return the wheels sans tires between xmas n new years. will ring you.
Old 12-19-2011, 01:58 PM
