i need to cut a dog door into a fiberglass door.
wife's orders.
i've installed plenty of dog doors, but all into wood doors. what am i gonna find when i cut thru my fiberglass door? styrofoam core? this even going to work?
poof! gone |
Parrothead member
Usually they have a foam core. but I have seen some with a cardboard honeycomb core.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
canna change law physics
You need to re-think this idea. Dog goes outside, is wet/muddy, etc, and lets itself in. What could go wrong?
I would love a cat door, but I expect several of the neighborhood cats would move inside.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Super Moderator
Uh, you must have missed this part: Quote:
i am against this idea..but yup. wife's orders.
we have an active racoon population..possums. i figured it is better to let her try, and when it goes sideways..buy another door.
poof! gone |
Parrothead member
I have one. Best thing I've ever done.
mine's large enough for me to use..
scent of the dogs will keep the critters away... Rika |
Bollweevil
The first time she walks in on a racoon chowing down on the catfood, your marching orders will definitely be to replace the door.. exact same thing happened to a good friend.
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
Tape the door with masking tape where you'll be cutting. Drill a hole use a fine tooth saw. If you're really anal have a spray bottle with water and keep the area misted to control dust. The end.
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
If you were closer I have a standard size exterior door I'd give you in trade for one with no dog door cut in it.
'87 924S (Sold) |
What?!?!
Get a second door and install the doggie door in that one and store your original door to reinstall when the wife changes her mind.
You know she will. Just sayin'.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
A SawsAll should make whatever kind of hole you need in that door. You may need to reinforce it around the perimeter of the hole.
Platinum Member
Can you put it into the wall next to the door?
300hp 1800lbs is the goal
haha... I put in a dog door for my <10lb Havanese cross. Very small door installed on a steel/aluminum screen door.
Middle of summer I let him out and went back to sleep. He came back inside and went to sleep. Hour or so later I hear a noise, but think nothing of it. Dog suddenly starts howling, and I hear the clicking sound of a dog walking across the floor. One of the neighbours pitbulls has jumped the six foot fence, and squeezed himself through the small opening. Luckily he was friendly.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
You do not have permissi
Buy one from the recycle place, a little paint, and use a cut-off wheel. They make one-way dog doors with chimes/alarms also. (They don't make wet 'n muddy dog sensors though.)
Meanwhile other things are still happening. |
MAGA
Our long haired dog is an outside dog.... The house would be full of hair, cat shiit, mud and stank if we allowed him inside. That said, I do let him sleep in the garage in the winter and I briefly considered installing a door for him to enter the garage.... Then one night he got sprayed by a skunk and I realized there is no way I want either a skunk or my dog after being sprayed by a skunk to enter at will into our semi finished garage.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
If there is space and a spigot near a door, you can make a dedicated wash-->drain pit area.
Good for boots and tools also.
A couple of battery operated remote controlled tabs on the inside part of the door and you can push a button and control what comes in when you want.
Or if you are not that lazy, just a manual slide. Dog can go out, but nothing can come back in till you release.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
disband
cliff, ive got a very good jigsaw that you can use. take the door off and work from a bench or saw horses. looking to hook up with you to return the wheels sans tires between xmas n new years. will ring you.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
