enzo1's Avatar
Jeep Grand Cherokee moose test -- the full story
76' 911s Signature Edition
Old 08-02-2012, 08:37 PM
Makes me feel real good about the new Durango I'm driving around in pulling a trailer....
Old 08-02-2012, 09:14 PM
Did you get the memo?
onewhippedpuppy's Avatar
Yikes. I would expect a car based SUV to do better.
‘07 Mazda RX8
Old 08-02-2012, 09:46 PM
What car is it based on?
Trick question, it's not. It shares underpinnings with the Mercedes-Benz ML and GL
It's unibody (like most cars), not body-on-frame (like most trucks)....maybe that's what you meant?
I love you guys outside this forum
-Eric
Old 08-03-2012, 07:25 AM
vash's Avatar
never seen a cone squished down so efficiently, that it pops!! cool.
and i cant believe th driver had no helmet on..the other guy..was that a bike helmet?
either way..i would duck and t-bone the moose. that is amazing.
poof! gone
Old 08-03-2012, 07:53 AM
Now in 993 land ...
aigel's Avatar
Vash, that wasn't the cone rather than the RF tire - every time. That's not a replay but 6 times they blew the same corner tire.
Scary stuff. It doesn't roll on that ideal surface, but it sure will if there is a curb, pot hole or other imperfection in the road at the wrong point.
I just drove behind a Grand Jerkey yesterday and looked at its suspension. It sure isn't the straight-axle old school truck it used to be any more. I would have thought that was an upside in the Moose maneuver.
G
81 SC (sold)
Old 08-03-2012, 08:04 AM
Paul K's Avatar
I'd be interested to see how my Land Rover would handle that.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 08-03-2012, 08:11 AM
Zeke's Avatar
Playing it over and over is simply alarmist tactics. Anyone of us could fix that thing with a set of revalved shocks. The combination of the tire spring rate and the chassis spring rate is overcoming the dampening of the shocks.
Possibly a rear bar change, but I'm not a suspension expert. I do know enough to know that matching dampening rate to overall spring rate is important as demonstrated by that "moose" test.
Old 08-03-2012, 08:20 AM
OOHH!! Let's set up a test!
-Eric
It's several individual tests with the same outcome. Not the same test over and over. Important difference.
-Eric
Old 08-03-2012, 08:21 AM
Quote de onewhippedpuppy
I was thinking unibody vs body on frame. Were that a tall old school SUV with solid axles I wouldn't be surprised, but a unibody SUV with a relatively low center of gravity and independent suspension should do better. The comparison to the Volvo and VW was a good illustration.
Old 08-03-2012, 08:33 AM
Yeah, they said that they popped 7 different tires (6 on camera) on 3 different Jeeps.
Yes, it needs better shocks, but then I guess the deal is that in other vehicles, they come from the factory with the correct shocks, but with the Jeep GC, they come with crap shocks that need an upgrade (and who knows if an aftermarket is going to have better valving). When you buy a brand new vehicle, do you plan to or think you should need to change the shocks?
My guess is that to make the GC ride as smoothly as possible, they underdamped it which seems like a very American way to go.
vash's Avatar
G
wow! i had the volume muted..thx
poof! gone
Old 08-03-2012, 08:37 AM
I suspect that the tires aren't blowing, just getting pushed off of the bead and losing all their air. That could probably be fixed with more pressure. It would be interesting to see what would happen with different air pressures and firmer shocks.
On the other hand, maybe you should not drive a Jeep like this. Whenever I drove my Ford F250 SD, I took it for granted that I had to be a little more careful than when I drove an M3, or a 911, or....
JR
Old 08-03-2012, 08:48 AM
Now in 993 land ...
aigel's Avatar
You can tell because the time of day in the videos - it is clear they ran this all day. The video editing sure could be better on that - announcing run 1 ... run 2 etc., so if anything it is non-alarmist. The Scandinavians tend not to overstate IMHO.
G
81 SC (sold)
Old 08-03-2012, 09:07 AM
Now in 993 land ...
aigel's Avatar
The key here is that the electronic stability control should never let the car get into this situation. And no - nobody plans on driving like this, but in an emergency situation, you may find yourself trying to avoid something at those speeds. In the VW and Volvo, you'll continue to drive, in this car, more likely you land on your roof at highway speeds and your camping trip ends in the hospital.
G
81 SC (sold)
Old 08-03-2012, 09:10 AM
I guess I'm a little old-fashioned in that I take a little personal responsiblity for what happens to me. I don't expect to be saved from any and every eventuality by some engineer making my cars idiot-proof. Maybe the Jeep could be made better. Maybe there's a factor in the test that exacerbates this behavior. I don't know. I have to say, after 60 Minutes screwed Audi, I have largely ignored these sorts of things.
JR
Old 08-03-2012, 09:31 AM
Now in 993 land ...
aigel's Avatar
All other vehicles have 4 wheel disk brakes, but you'd be fine buying a 4 wheel drum brake vehicle in the same category and just go slower? The issue is that other cars are significantly safer in the same market and price segment.
G
81 SC (sold)
Old 08-03-2012, 09:42 AM
I've found a lot of cars I've owned have one shortcoming or another. As an example, I found early Mercedes 4-Matic systems to respond so slowly to a loss of traction on one end that I could half-spin a car so equipped on a wet road before it got the other end hooked up and driving.
And yes, I do tailor my driving to what car I am in.
Maybe the Jeep should be better. Personally, I'd rather elevate the driving abilities of John Q. Citizen, than make an idiot-proof car. But, I get your point.
JR
Old 08-03-2012, 09:49 AM
I bet the Jeep would stomp those other vehicles in an off-road test.
However, you got to get there first, and that might be a problem.
Old 08-03-2012, 09:55 AM
