i've started reverse searing thicker steaks lately. basically, instead of cooking at high temp to desired doneness, you cook at lower temp first, then sear. this method will minimize that grey band of overcooked meat you get between the seared outside and the pink inside.
Cooking Temps: When To Cook Hot & Fast, When To Cook Low & Slow, And When To Do Both (Reverse Sear) |
In a slow oven on a rack until ~90 deg then sear in the skillet until ~125-130. A little carry over cooking gets you to med-rare while resting.
yum |
Olive oil burns at high temperature.
Evil Genius
I'm very disappointed in all of you..............
this post is worthless without photos: ![]() ![]() ![]()
Life is a big ocean to swim in. Wag more, bark less.
YUM
Neat trick with the onions on the BBQ - gunna do that myself next time. |
Bland
Whatever you do, don't try to make waffles with that technique... Disaster!
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Skillet is best. I don't add oil to the pan though. Take a nice thick cut of steak with a healthy rind of fat. Add salt/pepepr to taste. Stand the steak on edge (on the rind of fat) in your very hot skillet. As the rind renders down and crisps up it releases fat into the pan in which you then cook the steak. Only way to have it is rare.
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
A good steak is a good steak. You could eat it raw and it would taste good. The BIGGEST problem with grilling is overcooking. When my Weber grill is cranking, it's almost 600 degree's. I can cook a medium thick steak in 6-8 minutes, timing it and turning it over exactly half way through. Remove it from the grill and let it set 10 minutes and they are always great, as long as the steak is good to begin with. I never order steak out!
Just thinking out loud
It's all about the temperature and timing--> dependent on thickness. I've moved to a skillet, sear, bake from grilling. Same temperature, just a different method. 450-500.
The most common mistake is not allowing the meat to come to room temperature before cooking. Let set for 5 minutes before eating. If you don't have juice on the pan or plate for the baked potato, you're doing it wrong.
83 944 91 FJ80 84 Ram Charger (now gone) |
The key to a good steak is to pick a good cut, then season it well. That, and don't cook the crap out of it. If you want a good steak, you want it between rare and medium rare. Grilled steaks can be tasty, but some are better done in a pan, like a filet, or a skirt steak. Huge amounts of heat are NOT needed. I'd say the average guy places way too much importance on temperature when searing the meat. It only needs to be a little over 300 degrees at the surface of the meat. Blast furnace levels of heat just create an overly cooked layer on the outside.
Sear it at a reasonable heat and finish it in a slow oven. Baste it with butter, or other fat. Make a decent pan sauce while you let the meat rest. JR |
Evil Genius
For those who sear in cast iron on a side burner, then move to grill, while the meat is BBQing for that caveman DNA ingrained love of smoked meat, to the cast iron and left over fat scrape that pan hard to loosen all the seared bits and add thin 1/8-1/4" sliced red potatoes and onion rings and mushrooms to the rendered fat and crisp them up hot like potato chips.
Parrothead member
Grilled over charcoal> anything else...
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
AutoBahned
another trick is to get real chunk charcoal (NOT pressed sawdust briquets) hot hot hot, wave something over it to reduce the ash and put the meat right on top of it
flip the meat; pull it off, and knock off any coals brush off any ash (there won't be much) and gnaw into it |
Used Up User
![]() Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
AutoBahned
what's wrong with it are things like nitrosamines and other combustion products - they are carcinogenic
however, as Bruce Ames pointed out in reference to pesticide exposure, your body contains anti-cancer and detoxification mechanisms I prefer to use my detoxification mechanisms to deal with something tasty like a little grilled meat once in a while... |
Used Up User
Shame on you, Randy. For daring to discuss health & grilled steak in the same thread.
Ian
Being from Pittsburgh, we like our steaks made like our steel.
![]() Beef has more flavor if you cook it a little. Just not too much... This picture illustrates an even doneness, although it's a little too done for me: ![]() This is what you don't want and what you usually get if you use too much heat:
Evil Genius
Cooking with Cast Iron on both sides.!
When heating up my cast iron skillet on the bbq side burner, I place this in the pan to warm up too, and it keeps my steaks mo' flatter so they cook evenly, must weigh about 3-4 pounds.. Norpro Cast Iron Round Bacon Grill Press | Free Shipping
Seems that weight would squeeze out juices that you'd rather keep in the steak? Kind of like pressing a hamburger as you cook it.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
