2 post lift
I'm thinking of adding a 2 post lift in my shop/garage. The one problem that I am struggling with is the 16' width of the garage overhead door. I don't want to put the lift in a position that will prevent putting 2 cars in the building, but most lifts require 132 - 144" of width. One of the only lifts that I have found that requires less space is the Dannmar MaxJax which uses 110-125" of width. It also is designed for installation by the buyer with small posts with castors. The only draw backs that I see are the 6,000 lb max load and the 52" max lift height. Any thoughts or suggestions would be appreciated!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Another option is a Mohawk that doesnt use cables, just fluid for equalization. Not cheap but pro level and should last forever.
UnRegistered User
Check Craig's list for these. You find them on occasion. There seemed to be a million of them when the economy went south and dealerships and shops were closing up. Another bonus is the column height is less than 9 feet. I couldn't find one close enough to here to make it worthwhile.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
+2 on the Mohawk. I bought their A7 lift specificaly because it was the narrowest 2 post I could find. But it still might be tough fitting into a 16 ft bay.
Platinum Member
If you talk to Eagle, they will adjust the cable lengths, etc. for other options. I have their 2 post close to 10 years, and their 4 post almost 20, no problems with either.
