Wireless TV?
Is there a set where the TV can be wireless with a transmitter in another spot of the room?
We can get power. Just need to get the cable to a wireless system. We need a set up like that for my son's room at school. |
The Unsettler
You can pick up aftermarket streaming devices but they are a) not cheap and b) a bit spotty.
Look at the Silicon Dust offering, HDHomeRun DUAL - Generation 4 - US - Watch Streaming TV Anywhere You'll still need a PC at the TV, unless it's a Smart TV that supports DLNA streaming. A PlayStation 3 will work. You could also go Raspberry PI, cheap and comes with OpenElec as a an OS option but the PI is painfully slow on channel switching, menu navigation etc....
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
30 feet of coax and some floor tape? Using wireless to span a dorm room seems a bit much.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
The Unsettler
Run it along the baseboard. 50 footer at Loews, $15.00 5 minutes of work.
True, but it would cross two door ways and we were trying to avoid that. I didn't know if there was a cheap wireless out there.
Since it's a dorm room, I might try those stick holders with zip tie and just go around the ceiling. Quote:
Dog-faced pony soldier
Can you just plug in an Apple TV box and connect to a wifi connection? That's all I do. Only cords involved are the power for the screen, power for the box and HDMI from box to screen (can be virtually any length you want - 3' or 50' away).
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Student of the obvious
Haven't used this, but other Rocketfish stuff I have has been great:
Rocketfish™ - Whole Home HD Extender - Black Transmits through power lines, so may be an issue in a dorm.
Lee |
Navin Johnson
I have a Brite-view HDelight gizmo that I have to beam my STB to a tvin my kitchen..
Yea this was a more expensive way to get the tv into the kitchen. However my house is 110 years, old stucco exterior, plaster interior. I don't like cutting unnecessary holes in the plaster if I can avoid it, and pulling cable though the walls is a pain. So I got the brite view unit. The receiver is about 25 feet from the transmitter, It very rarely drops the signal.. So far it has worked well for my for a few years..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
wireless TV has the creepiest commercials. hahaha...
poof! gone |
$200.00 at Best Buy. Provides a wireless connection between the cable box and the TV.
