Air Medal or two
afterburn 549's Avatar
Gas holes tops of pistons
Windsor 302
Nephew already bought pistons for his wana be lil cruiser car (1962 Comet ) KOOL !
He has most the stuff to make it a real fun engine for .
Cam, manifold , .011 decked block, 60 CC AL heads with 202 valves and all.
SO
I was trying hard to adjust the drag of oil rings on these so called "performance pistons".
Come to find out after much frustration they are just hyper pistons with a moly skirt.
They fit nice-
BUT he has standard go to twn Aunt Tilly grocery getter rings !
OK, cant send pistons back. Cant allow 40 pound drag rings in there either!
Is it a BIG trick to drill tops for gas operated low drag piston rings ?
This does not look like a magic trick.
OR should i just send them out, to where, for some holes ?
Your opinion?
thanx
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 07-14-2015, 02:21 AM
What hp @ what RPMs is he expecting to turn? I use standard rings ,moly faced top one in a 347 , stroked 302 Windsor, which dynoed @ 468 hp @6400 flywheel. I regularly wind it to 6800 and don,t think I left much on the table (KB icon forged pistons ,AFR heads ,Anderson N-71 cam ).
Your standard cast rings will have less friction after they break in.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 07-14-2015, 08:05 AM
Still Doin Time
asphaltgambler's Avatar
The benefit largely depends on: ring land / location, ring thickness, and max RPM. The problem with running that even in limited street use is carbon build up plugging the tiny holes..............................all based on my experience.
I would consult the piston manufacturer as to what they recommend. Hopefully you'll get a knowledgeable guy on the other end of the phone.
Old 07-14-2015, 08:10 AM
Model Citizen
herr_oberst's Avatar
Here's a little discussion of gas venting:
Vertical or Side/Lateral gas porting • Speed Talk
Old 07-14-2015, 08:14 AM
Air Medal or two
Can or would someone point me to a part number or place that will sell a med drag ring?
The rings he has now takes a freight train to move the piston with JUST the oil rings in there.
I did not even measure it as its just TOOOOoo much
Thanx
Next -
He is hoping for 400 HP at around 5500 its not a real race car, i call it a Ricky race car.
More of a ego trip....But then i think it all is anyway.
Asphault, - thanx for the tip
and thanx johnsjmc. Goood job on HP ! looks usuable
This car is just a hamburger dan car Sat night Special
Old 07-14-2015, 09:54 AM
