Eva
So, I'm in a similar but different situation with my 3.0 motor.
It (very likely) has a bad valve guide on #2 because the exhaust side comp is like 90% leak down, basically running on 5 cyl when I pulled it, but all other leak down numbers are right where they should be. Am I crazy for planning to yank the left carrier, try to pull only that cylinder and fix just that? Engine has 167k on it, only 34k on top-end rebuild.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Grip It & Rip It
What barrels are you going to get? Same pistons?
Did you have alusil or nikasil?
82 911SC (sold) |
Not crazy, that's what I would do.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Eva
I'm not asking to be a wise arse, I'm being serious. Why not just fix what's broken instead of the toss cash at it just because approach...
Grip It & Rip It
Sorry-
Question was for original poster. Your plan sounds good to to me ![]()
82 911SC (sold) |
Nikasil. I will be putting the factory Mahle units on. I believe the new ones will also be Nikasil.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
We my engine was apart I was real happy I went "all the way" because the intermediate shaft bearings had some significant wear. How was the shaft bearing on this engine?
Cool project to document. No doubt many of us would love to be there to get in your way and ask stupid questions and slow thing down. ![]()
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
![]() The guys at the shop seem to think having this motor here is a "borrow parts" paradise. Fine by me since they replace what they took with new. ![]()
My wallet just got a whole lot thinner.
Im curious to see how you go with those Glyco bearings.. clearance wise...
![]() Building these engines is not an easy task as you know. The sheer parts count is astounding! I received my STOMSKI crankshaft holder today. What a piece of craftsmanship! Can't wait to use it Friday. BTW, Great customer service too. Steven Stomski, if You are following this thread, Thank you! Pics to follow.
I am not getting too much done today. I took the rods off of the crank. One set of the bearings on #3 cylinder had some significant scratches on them. The rest of the bearings looked pretty good. The crank is being shipped off today to CCR to have it mag checked, cleaned out, and polished up.
I also dropped the engine case off at the local steam cleaners to have all the cracks and crevices cleaned. I need to go pick that up before they close. The rods are going to German Precision to be done. I have two sets of 3.2/3.3 rods already done that I picked up today. Both have ARP rod bolts. One set is for this motor and the other set is for sale if anyone is interested in them. ![]() ![]() ![]() ![]() ![]() ![]()
Today is head stud removal day. I am replacing the original studs with all steel "Raceware" studs. The last stud (upper #3 nearest the flywheel end) is the worst one to remove.
Cars Ruined My Life
3.2 Carrera engine project (to be sold)
Now the fun part begins.
Sent from my iPhone using Tapatalk Last edited by impactbumper; 08-20-2016 at 11:19 AM.. |
I wish I could tumble that case for you Dan.
Tru6 Restoration & Design |
Me too Shaun.
You are a true professional Dan and a credit to Porsche Independents! I'd wager few are dedicated to that kind of attention to detail, time and care.
Gorgeous work Dan. Wish I was nearby, I'd offer to be your shop ***** just for the experience.
![]() Gotta make sure those case oil squirters are clear! ![]() ![]()
Studs back in and case is cleaned and prepped for assembly.
Thread Tools | |
Rate This Thread | |
