ASD ASD is offline
ASD's Avatar
Cut it off? Welding question
I have a 73 Volkswagen THING, its a whole lot of fun and I enjoy it often.
Recently I obtained a factory Hard Top which is kinda rare. Its in great shape too.
Here's the deal, my THING has a roll bar with a peak in the middle bar 30" back from the windshield.
The top will not go over the bar.
I am considering cutting the roll bar. But how far do I want to cut?
a. all the way off to the uprights.
b. leave enough of the cross bar on each side to weld a straight piece onto
c. cut out the peak part and then weld in a straight bar
I can't weld - well I have but have no equipment.
So I can cut the old bar ( recip saw) but will need to hit a shop in warmer weather to get the welding done
Ideas are appreciated
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 12-08-2016, 07:19 AM
I see the peaked bar in the photo. Assuming that the ONLY issue with the bar is the one peaked bar in the middle, then I would probably go for option C. Just replace the peaked bar with a straight bar.
Old 12-08-2016, 07:29 AM
ASD ASD is offline
ASD's Avatar
cut it all off? Or just the peaked section
Old 12-08-2016, 08:36 AM
Platinum Member
dad911's Avatar
I'd leave stubs on both sides, about 12", then find a tube with the same ID ad the OD of existing bars. Slide over and through bolt, like the Autopower 911 Roll cage. This way, in the event of an incident, the stubs would be safer.
I'm not a cage designer, but without diagonal bracing, is it functional or cosmetic? Why keep the roll cage?
Old 12-08-2016, 08:50 AM
ASD ASD is offline
ASD's Avatar
I like that idea. 12" ? Sounds like a winner
I like the way the roll cage looks when I use the bikini top. warm weather times. I don't drive it off road any
Old 12-08-2016, 08:53 AM
Platinum Member
dad911's Avatar
Then dare I say it? Pvc painted black for the summer time......
Old 12-08-2016, 09:01 AM
ASD ASD is offline
ASD's Avatar
Thats one idea, cheap too..I think I will try to stay metal..
Old 12-08-2016, 09:10 AM
ASD ASD is offline
ASD's Avatar
I am wondering if I get metal pipe, and the stubs are 12" long, how would the pipe go over them. Seems I could get them over shorter stubs maybe.?
Old 12-08-2016, 09:18 AM
The Unsettler
stomachmonkey's Avatar
As long as the overlap of the new pipe is less than 12 inches, like 11 15/16 will do it.
"I want my two dollars"
"Brandon Won"
Old 12-08-2016, 10:11 AM
You do not have permissi
john70t's Avatar
If the frame is one solid piece, this doesn't require any welding but leaves ugly bolts:
(Pardon the over-engineering.)
Old 12-08-2016, 10:16 AM
Arizona_928's Avatar
Option c. Find a local welder to moonlight. Can't take more then an hour including cutting the bar.
dolor et pavor
Copyright
Old 12-08-2016, 10:21 AM
You could cut just one side, remove a bit at the cut, and then with a portable pipe bender, take out the hump. Then just have someone reweld and all will be good again. Only issue I see it that the center pipe is angled up where it is welded to the side pipes. So to be perfect, I would just cut it out and weld in a new straight one. This would be the fastest way to do it and have it look right.
Von
http://vonsmog.com
73' 911T Coupe, 76' 911S Targa
73'& 80' Mercedes Unimog DoKa
59' Austin Healey 100-6
Old 12-08-2016, 10:24 AM
VincentVega's Avatar
How much headroom do you have with the center bar? I wouldnt want to hit my head on that thing.
Old 12-08-2016, 10:32 AM
Platinum Member
dad911's Avatar
Sorry, it was a bad idea. I think PVC would have sharp shards when impacted.
If you cut it to 13" less than the width between the sides, it would slide over one side, then align and slide over the other.
Old 12-08-2016, 11:07 AM
Eric Coffey's Avatar
+1
If you were to just cut out the center section of the peaked crossbar , the "stubs" would still be angled. So, the only way to deal with it is to completely remove the peaked section and weld in a new straight piece.
Old 12-08-2016, 11:59 AM
ASD ASD is offline
ASD's Avatar
I just noticed that myself...I guess I will remove the whole section, leave it out for the winter, then get a welder to add the straight piece in Spring...
Thanks guys,,,
Old 12-08-2016, 12:30 PM
A better option.
1987 GP White 930
1977 Ford Bronco
Old 12-08-2016, 04:42 PM
Is that roll bar a factory option? I'd say without diagonal bracing it will not provide any roll protection. If you want to drive the car get a proper roll bar designed and installed - otherwise you are driving a death trap. Someone pointed out the bump in the one bar might be there for head clearance - very good point. If you put in a straight bar - you or someone else could hit a bump and bump your head.
Sold: 1989 3.2 coupe, 112k miles
Old 12-09-2016, 08:10 AM
ASD ASD is offline
ASD's Avatar
no head bumping unless you are trying to stand up. I dont off road and the Thing is very stable..
Not a factory roll bar
Old 12-09-2016, 08:14 AM
I would lose the rollbar. Why try to keep it when you are installing a hard top?
Old 12-09-2016, 08:18 AM
