Dave |
Double post.
Day 1 after the resolder. No events so far. Here's to hoping.
Which solder was bad?
Can someone identify what is wrong in this photo? Curious how to identify good vs. broken solder. They all look the same to me.,
1986 Bosch Icon Wipers coupe. |
Chain fence eating turbo
Looking from my cellphone, it appears 3 and 5 are cracked. See the darker parting lines half way up the ‘mountain’?
3 and 5 looked bad. It's a zoomed in cell photo so it's hard to tell. I redid 3, 4, and 5.
Here are some pictures from other people of what a bad solder joint could look like on the ECU. ![]() ![]() Good short thread on the subject: http://forums.pelicanparts.com/porsche-911-technical-forum/652375-dme-bad-solder-joint-repair.html
Solder joints should look shiny and smooth like 1, 2, 4, 9. Even 10 and maybe 11 looks like it might be breaking.
The larger the part being held on by solder the more chances of this happening.
Find Spoke's LED Products: www.spokeworksled.com |
A lot of Bosch solder work from the period was just awful. Solder joints should look smooth and shiny. And a fresh one is bright and shiny. That last will oxidize and dull over 4 decades - especially as that is "real" solder (== "contains lead"). But rough, dull and lumpy? No good solder joint looks like that. It's sort of like welding; once the joint is up to temperature, the metal is hot enough to flow and gets wicked in - at the same time, the flux burns off, because its done its job.. Another dead giveaway is big puddles of flux around all the solder pads - like my Bosch climate control had... Did the factory do better solder work on that Motronic, or did they just wash the excess flux off with solvent? I know which way I'd bet... Worth pointing out that reflowing your solder joints can also affect how willing someone might be to repair the unit later; many of those components can be damaged by excessive heat, and an expensive electronic box probably not the best place to learn that skill.. But it's not difficult, exactly.
'77 S with '78 930 power and a few other things. |
Ya, I only did the 3, 4, and 5 for a few reasons. 1) They have repeatedly been shown the community to be an issue, 2) Two of them were actually cracked, 3) They would have the highest tolerance for heating and soldering by an amateur without causing damage.
The others looked fine to my untrained eye. Keep in mind you are looking at a low quality cell phone photo. As for the original Bosch quality, well, it's 30 years old before it started giving me issues. As for your last point about monkeying with it and then not being able to get a pro to work on it, that's a fair point. I will keep that in mind. In the mean time day 2 had no issues as well. I am almost cautiously optimistic but the pessimist in me still doesn't think I fixed it. |
In 1986, how were these solder joints done? By a robot?
Usually circuit boards were mass soldered with a 'wave table'. Board would be held above the pool and a 'wave' would wash the bottom of it in solder, fusing all the points at once.
It's actually quite common for any old solder joint to eventually crack due to vibrations and road use. Older BMWs suffer from this as well, either from the DME, the gauge cluster, the Info Panel, even the warning panel in my friends 88 RX7 had these issues (his clock worked half the time due to this issue). I took aviation classes in college and learned the art of repairing electrical circuits and 90% of the time all these Gremlins were fixed by a simple reflow..
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5 |
Actually that's not true. These fatigued solder joints shown in the pictures resulted from vibrations
and how components were mounted to/on the circuit boards. Besides, mounting the DME ECU on the vehicle's floor under the seat didn't help. No other areas of the circuit boards on the 911 3.2 DME ECU rarely if ever fails. Please, no guessing.
Dave Last edited by mysocal911; 07-07-2018 at 09:08 AM.. |
Yep, there’s no vibration protection on these old DME’s.
Add taught, filling-rattling suspension, and it’s a recipe for cracked joints. |
Later Porsches (986/996) had the DME ECUs mounted vertically, i.e. reduces flexing of the circuit boards.
Dave |
Great point
Still here
I don't see where else Porsche could have mounted these units unobtrusively though on the 911 given the interior space, or lack thereof. |
In my case it was broken solder points fixed by Ingo. Has worked perfectly ever since he did his magic. I later ran into a random no start and Ingo helped me isolate it to a randomly failing RPM sensor.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Update. It's been a week at the problem has yet to reappear.
That's why I have been telling anyone that will listen to send the Motronic unit to Ingo during the "off-season", the intermittent issues this can cause will make you crazy trying to chase down.
Gary R. |
Sorry you wasted your time and money not fully reading and listening to Pelican members and simple DIYs.
Dave |
