Silly question: Where are you placing the jack stands for a front suspension rebuild?
Normally I put the jack stands under the front A-arms.
But where is a safe place to put them when you're planning on removing the A-arms? I get nervous thinking about bending a pinch weld..
youtube.com/bennyobscene
Old 12-17-2018, 10:40 AM
I ended up buying the flat top esco jack stands for this job. Added to the expense a bit but outside of having a lift they seemed like correct solution for a-arm removal.
1982 911 Targa, 3.0L ROW with Webers
Old 12-17-2018, 10:45 AM
There is a diagram somewhere on here that shows the lifting points.
I cut a couple small pieces of 2X4 that fit in the flat corners of the pan behind the front wheels. The lifting spot where the threaded hole is.
The wood gives it cushion and reduces the chance of denting the pan.
Derrick
Old 12-17-2018, 11:06 AM
Bollweevil
This ^^^
I use a 6" x 6" piece of plywood between the jack stands and front pan. ('74's don't have the reinforced lifting point).
Being somewhat paranoid, I placed the front tires behind the jack stands with a 4x4 laid on top of them just in case.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 12-17-2018, 12:36 PM
Source a length of 2x4 or 2x6 lumber to span the distance between L and right sides, then position jack stands under it. See above photo for front support placement. Careful. Avoid compressiung the oil cooler and/or A/C lines. Additional supports provide comforting redundancy, just in case.
Sherwood
Old 12-17-2018, 02:09 PM
Thanks! Lucky(?) for me, I have neither oil nor A/C lines to crush...
Old 12-18-2018, 05:53 AM
donagain1's Avatar
Not a silly question at all, and your timing is nothing short of perfect... I'm looking at doing my front end and want to get it in the air as high as possible.
A mental exercise in the middle of the night while trying to get to sleep gave me visions of sistering the bottom chord of a roof truss with a couple 2x6s to reinforce it, wedging a 4x4 post sitting on a suitable Simpson Strong-Tie bracket from Home Depot that's anchored to the garage floor so it won't kick out, slipping another 4x4 beneath the car from side to side with some 2x4 scraps tacked on and judiciously placed to catch the lift point seams, then sticking a couple 2K pound capacity come-alongs on both sides of it, hanging from the beefed up truss and jack the front end up until the roof hits the high ceiling... a homemade gantry crane as it were. Then the vision came to me of a heavy vehicle bludgeoning me to death when it fell from a distance of four or so feet, so I rolled over and went to sleep. Has anyone ever jury-rigged a similar contraption and lived to tell about it?
Don
Rocklin, CA
-85 Carrera
Old 12-18-2018, 12:59 PM
1980 911 SC
Life's a Beach
Old 12-21-2018, 01:59 PM
Registered Minimalist
75 911s's Avatar
Made an Xmas list for my wife and this showed up today.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-21-2018, 03:07 PM
