1990 964 C2 suspension upgrades
Hi,
I am looking to upgrade the suspension on my 1990 964 C2. I will be driving the car mostly on the street with occasional track days. I am not looking for very stiff springs and want a ride similar to stock with enhanced handling. I have been looking at the following: Bilstein PSS10 Bilstein HD with H&R springs KW v1 KW v3 H&R street performance coil over strut tower bar (I have one) urethane steering rack bushings steering rack brace 993 GT2 inner tie rods H&R adjustable sway bars replace front control arm bushings with slightly stiffer rubber ones leaving rear trailing arm bushings stock replace spring plate bushings similar to stock only if bad Please let me know your thoughts and experience with these components. Thanks David |
look at my build thread linked below
https://rennlist.com/forums/964-forum/904951-my-964-c2-transformation-build-thread.html On the 964 monoballs and solid suspension components do not contribute to harshness as much as poor shock setup damping and calibration. I've driven 964 that feel much less supple and controlled than my car that have full rubber bushings the goal here depends your objectives. I do not like Bilstein shocks on the 964. Never driven one or in one that didn't feel harsh and overly damped. Last edited by spyerx; 02-04-2019 at 05:38 PM.. |
Lufty Expert
I run mono ball upper front, the rest rubber OEM, and H&R with bigger bars. It's perfect for the street. Firm but not to stiff, drives really nice.
I might have a set of h&r coilovers and bars available if you’re interested ?
I’m still unpacking parts now I’m going on my 964 project , but have found one front and one rear and a pair of anti-roll-bars upto now .. Pm me if interested and I’ll let you know what else I uncover . IMHO , the full h&r kit is bordering on the extreme for a daily driver even using all factory rubber . A lot more control and a better set-up than the trusted bilstein/Eibach or bilstein h&r combos , but the bars make it a little too much for my liking . ( I’m old btw ) It’s a definately improvement on bilstein/h&r 965 springs which is pretty hard to beat for a fixed-height street combo on a stock car . Yet it offers no adjustment on the dampers for track use so ch2anging springs to the extreme is out unless you send to bilstein for revalue . * Allthough the balance and anti-roll are adjustable , which is good as that’s more than enough to play with ![]() * Like lots of porsche Oem parts manufacturers , the big players in Europe all get along . (Your m-option will be eibach or h&r etc) So h&r height-adjustable are modified bilstein dampers , and can be serviced/valve at bilstein Motorsport centers . At least in europe they can , but better check over in USA .... Last edited by ian c2; 02-04-2019 at 07:10 PM.. |
When I got my '90 964 C2, I upgraded from stock suspension to Bilstein HD and H&R 965 springs. This is one of the more common upgrades done.
Also have stock sway bars and Elephant Racing 'sport' hardness rubber bushings all around. My car is 100% street driven and I have never driven any other 964's. I'm totally satisfied with how mine performs and the limiting factor to my car's performance is not my suspension setup but my driving skills. It performs more than well enough on the street. |
I own a couple of couple cars , and each one of them is a more accomplished car than I am an accomplished driver ![]() ![]()
I have H&R coilcovers on my 90 c2, I love them. I take it on 5 hour road trips routinely within the state. Lots of different road conditions. I would say stiff suspension to one person may not be stiff to another. That one is tough to gage. I don't think mine is that stiff, but I also don't think GT3's are that stiff. If you are use to riding in a cush SUV then you are going to think anything is stiff. So it really depends on what you are use to.
You want a digressive valve stack PSS10 comes stock w/ a digressive stack matched to the car and for mostly street use might be the way to go. The nice thing here is that it'a complete engineered package, nothing extra to buy The Bilstein hd and H&R(H&R is made by Bilstein) you would want to have a digressive revalve done and you ill need springs and perches which are usually sold separately Don't know about the KWs The rest looks good, Elephant or rennline sport rubber for the bushings is a great way to go.
I went with Bilstein hd + H&R lowering springs - the really common upgrade combo.
I also added the Elephant racing bump steer correcting tie rods - this makes a huge difference. This was the stiffest I could go and still enjoy the coastal roads in Oregon. If it were my only 911 however, I would have definitely gone with Bilstein PSS10.
Steve '66 912 - Polo Red; '74 911s - Silver Carrera RS clone '77 911s - Peru red IROC Clone '89 964 C4 - Guards red |
I have the Eibach Pro kit with Eibach adjustable sway bars and endlinks. Great ride, not too low or too stiff, but I am bias since I work there.
Thanks Guys. Lots of good information. My biggest decision is buying the shocks/struts. I really like the PSS10, but not sure if I want to spend that much money. Too bad a good used set isn't available for sale. Is there anything comparable to the PSS10 for less dollars?
Check the tops on the rear of your car .
They change the design during the 964 run . There’s a work-around if needed. |
I think the extra you pay for the PSS10 is negligible if you use it. Nothing is worse than buying shocks/springs (such as HD+HR springs) and realizing you should have spent a little more to get adjustability for track use.
You'll be really bummed if you go through the work of buying and installing something less expensive purely to save money and find out it doesn't perform the way you need it to.
Wow! Mr DFH.
That’s the best advice I heard. You are 100 % correct. This is what I would say, but dont always practice it. PSS10’s it is |
If you know what you are doing adjustability is great. JMO but for most people having custom adjustable shocks built to your spec(chassis, springs, use) is the best way to go. Here you rely on the skill and knowledge of the shop or shock builder. Elephant can provide this service for Bilstein, H&R and their line of Vonn shocks. The one constant is to use a digressive rather than linear stack. MCS is probably the best w/ 964 price range from ~$2700 to ~$6000 a set + springs & perches PSS10 are digressive stock and are a good value as you don't need to buy anything else, It can be instructive to DIY adjust them
Which shocks are you running with the Eibach kit? Car looks great.
1990 964 C4 |
Thank you. Still stock shocks.
Great, thanks! I have Bilstein B6 with OEM springs, and looking to go to the Eibach springs. Got sidetracked researching every coilover though
MCS 1-way look very nice, but probably overkill for my street driving and occasional Porsche club multi-day touring events.
1990 964 C4 |
Can anyone confirm these spring rates are accurate for the Eibach kit?
1990 964 C4 |
The Eibach rates in the table are correct
