autojack's Avatar
Verify my CHT sensor test results
My 3.2 has always had a kind of rough idle when it is first started. It starts out strong, but as it begins to settle down towards the 880 rpm speed it starts to hesitate a bit. It isn't hunting around wildly and hasn't fully stalled, but sometimes seems it is about to before suddenly correcting. Once it has been running for 5-10 minutes the problem goes away.
The distributor cap, rotor, plugs, and wires were replaced 18k miles/7 years ago. I just cleaned the IAC valve, it was pretty clean to start with and didn't change anything. So next I measured the CHT impedance. I got the following results:
4.3K ohms when engine was dead cold, 21C outdoor temperature.
160 ohms after the engine had run for 5 minutes or so.
Based on the chart in the Bentley manual, it looks like the cold reading is too high (indicating colder than it should) but the warm reading is in spec. Seems like this would explain why it starts off rough and then gets better. I have a replacement sensor, and it measures 2.18K in ambient air.
I was hoping someone with experience can check my work and confirm before I go to the effort of replacing the sensor, because I know from experience doing the speed and reference sensors that it's going to be a pain in the neck.
Old 02-10-2020, 03:14 AM
proporsche's Avatar
here is a little help for you
1985 911 with original 502 191 miles...808 198 km
Old 02-10-2020, 04:12 AM
Bosch NTC sensor is nominally 2.5 KOhms @ 20C, +/- 5%.
4.3 KOhms @ 21C is a very long way from 5%.
Bosch datasheet says:
Characteristic Application
T [°C]R [Ohm]
-4045,313
-3026,114
-2015,462
-109,397
05,896
103,792
202,500
301,707
401,175
50834
60596
70436
80323
90243
100187
110144
120113
13089
Here: Temperature Sensor NTCÂ M12
'77 S with '78 930 power and a few other things.
Old 02-11-2020, 11:37 AM
autojack's Avatar
Oh, the data sheet info is great, I didn't even think to look for one! Thanks. I'll definitely be replacing it. I hope it helps with the cold idle issue.
Old 02-11-2020, 11:57 PM
autojack's Avatar
Just to follow up on this: I did replace the CHT sensor and it fixed the idle issue. No hesitation anymore when it's cold, just nice steady running.
Old 04-19-2020, 12:51 AM
That is good to hear. Where did you buy your CHT sensor from? Right now the only one I can find is available from Porsche, which to say the least is a lot more than I want to pay. I Assume you replaced it with the updated "2-wire" version? Thanks.
Old 04-19-2020, 08:59 AM
The VW/914 sensor fits the 3.2 head (same reach/thread) and available all day long for $20. It's only a single-wire - and you'd need to extend it.
Old 04-19-2020, 09:11 AM
Problems associated with a temp sensor are simple:
1. Temp sensor resistance indicating greater than 5,000 ohms when warm, results in black smoke when the engine is warm.
Use a paperclip to bypass it for testing.
2. Temp sensor resistance that's too low when cold, results in poor starting/running when cold.
Dave
Old 04-19-2020, 10:02 AM
autojack's Avatar
I bought the Bosch version from Pelican. $97.
https://www.pelicanparts.com/catalog/SuperCat/819/POR_819_FULEMI_pg1.htm?highlight_part=0-280-130-070-INT
Old 04-20-2020, 02:00 AM
Originally Posted by autojack View Post
I didn't realize they were back in stock, thanks. Good to know. URO was suppository working on a replacement parts also.
Old 04-21-2020, 07:38 AM
Pelican Parts Vendor
UROParts's Avatar
Looks like the Bosch is currently out of stock at Pelican, if you try to add it to the cart it redirects to Genuine. Strange that Pelican has the Bosch listed for such a low price, it's $299 at the big jungle retailer. Maybe it was on clearance?
In any case, our Cylinder Head Temp Sensor 930 606 915 00 is now available, and we've sold about 130 so far: https://www.pelicanparts.com/More_Info/93060691500.htm?pn=930-606-915-00-M253&SVSVSI=0819&DID=13864
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 04-21-2020, 09:01 AM
