Mysterious Electrical Connector
Just finished doing the contact fix for the headlight dimmer switch on the steering column and it was easy and fixed the headlight issue. I was going to follow that repair with installation of the JWEST relay kit. The first thing I noticed when looking at the fuse box is the location where the new relay kit is suppose to mount that there is already some electrical connector there. I have no idea what it is or what it does. I'm the second owner the po did have H4 bulbs and Bosch glass installed Other then that I'm clueless but would welcome everyone's thoughts.
She has a wide ass but I still love her |
What year, and where does that bundle of wires at the right go to?
I may not to be able to help with your electrical questions, but is that a rare Turbo Targa? Or Turbo flares added to a regular Targa? More photos please! Mark
1979 911SC Targa |
Designer King
What are the numbers, or other writing on the side of that thing? You may be able to Google or check the PET with those numbers.
That may be just a connector, or you may already have a relay.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
My '87 has that connect there. When I installed the relay kit, I just kind of tucked it (connector) behind it. Not sure what all the connector is for (too lazy to look it up)...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
First owner had the engine rebuilt and they used 3.5 pistons and jugs, ported heads, performance cam, chip and muffler. |
Thanks, I'll take a look the numbers this evening and see what I come up with. Because the po changed out the bulbs to H4 type and did the Bosh glass i was thinking it might be headlight related wiring and connector but not sure. I think I might just disconnect the coupling and see what happens. If the headlights still work then install the relays.
That's good to know, the connector and wiring install looks very clean and done very well but the wiring is wrapped in electrical type friction tape which made me think it was an after market add on.
If you look closely at the connector, you can actually see the Porsche parts logo molded into the plastic. Actually, they did use "friction" type electrical tape around the car, especially in the interior and trunk areas. Normally this was via the harness makers (Draxelmayer, etc.).
1988 3.2, I have one as well. No idea.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
FWIW, on my '87 that same connector controlled the power to the Frunk light bulb and to the left and right interior lights in the cabin.
The same lights were flaky and I couldn't diagnose why it kept flickering until I installed the JWest relay kit, to which I stabilized the connector by screwing it to the relay. No problems since. Last edited by Ok here we go; 07-29-2020 at 01:56 PM.. |
Snitzler
A picture makes it so easy for those of us without great electrical expertise to understand things and there again all the other pictures I've seen didn't show the connector which is why I was concerned to begin with. Now i'll feel comfortable installing the relay. Many thanks and I appreciate you taking to time to post the picture. |
Thanks |
I'm no expert either. I tapped the connector, and the lights flickered. 1+1=2 for me. Good luck chasing the gremlins.
Paul 1987 Carrera coupe |
For what it is worth the connector number is 94461255100 and listed as a Genuine Porsche Part: ELEC. SOCKET-6PIN.
Again thanks to all for the help. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connector.
https://www.google.com/search?sourceid=navclient&aq=&oq=944-612-552-00&ie=UTF-8&rlz=1T4GUEA_enUS570US570&q=944-612-552-00&gs_l=hp....0.0.0.9072...........0.qxpWBF_bMlY#spf= 1596063222857
![]() ^^^^^ Hope this helps. For our '86. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
