If you actually put fluid into the bottle, be careful about the condition of your line. The plastic line broke for me due to age and got fluid into the trunk. Go to Home Depot and get a replacement line if you haven't done so already. That brake fluid is corrosive...
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
You run the risk of damaging the seals in the master cylinder as they go beyond their normal range of travel into an area of corrosion.
AutoBahned
pressure bleeding will not introduce air into the system
- unless you let the fluid level in the m/c get too low |
porsher
i.e. allowed full hydraulic pressure to reach the rearthe rears could start working too hard, overheat, wear out etc... just an off the wall idea
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Going to bleed the rears the two person traditional way. If the does not have the desired effect will pressure bleed or rebuild rear calipers. If still not perfect will replace mc . |
I have the same condition, only reversed. I rebuild all calipers, with new pads and have rear brake bias. I take it for a ride and the rear brakes are smoking, with the front only warm. I'm going to replace the master cylinder. I can't find a Ate Master Cylinder, out of stock, everywhere, for a reasonable price.
Any other Master Cylinder recommended. 1981 911sc Last edited by coolmac; 11-10-2020 at 12:51 PM.. |
porsher
i have always wondered about buying a brake pressure gauge but never had a good reason
Is there a repair for this or is replacement of the master cylinder the only option?
Mike '89 CARRERA #402 |
I suppose you could rebuild the MC by honing the bore and putting in new seals, but I suppose most people just buy a new one. Others who have actually done a rebuild may want to chime in...
