mysterious wire
I found what looks like a solid black wire that is not connected to anything under the dash.
Here is a photo of the mysterious wire.
Old 12-16-2020, 03:14 PM
What year and model car are you working on?
Old 12-16-2020, 03:40 PM
^good point! Should have said this is a ‘72 911T
Old 12-16-2020, 04:04 PM
It’s probably two wires in a outer covering. Did 72’s have a ignition buzzer? Usually that’s the wire that people ask about when they find it disconnected. There would be a jack on the ignition body if your car has the buzzer.
Rutager West
Old 12-16-2020, 04:25 PM
Did some research on ignition buzzer and looks like you may be right.
Old 12-16-2020, 06:40 PM
proporsche's Avatar
if you make a beter pic of the connecter we would know for sure;-)
1985 911 with original 502 191 miles...808 198 km
Old 12-16-2020, 10:54 PM
True - the end is out of focus as I was trying to squeeze myself under the dash to look up
It is just a standard spade connector.
Old 12-17-2020, 06:01 AM
proporsche's Avatar
standart for Porsche or not is the question;-))
Ivan
Old 12-17-2020, 06:56 AM
