-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   G-Body Numeric Racing shifter (http://forums.pelicanparts.com/showthread.php?t=1088263)
BE911SC 10-08-2022 11:51 AM
Originally Posted by 912outlaw (Post 11810380)
Hey ton I just posted on this thread about the lockout problem. Did you get yours to work. When I go to 5th the shaft barely skims the lockout tooth and then when in 5th the shaft settles even further away from the lockout tooth. Have no clue. I played with that little Allen screw. Don’t really see what that even does. I feel the shaft just needs to be closer to the lockout. All gears go in although when shifting from neutral to 5th there’s basically no movement to the left when shifting. There’s no confidence in the least from 5th to 4th. Even 3rd to 4th is touchy and really gotta pay attention. Is it just me or others have these issues. Thanks
I have slightly zinged reverse twice coming out of 5th and thus do that more slowly now. 3rd to 4th seems fine, I just carefully pull it straight back. I opted for the extension and it puts the knob right where I want it. Muscle memory is important to develop here since the shifter changes the feel so much. Nice unit but for the fiddly lockout.
inastrangeland 10-27-2022 12:33 PM
The lockout has to be on the passenger side for the 915 trans. That is where reverse is. The left side is for the 901 trans which has reverse on the left side.
I installed this shifter in my 901 trans and have had no issues with lockout. I have the heavier springs and the extension and would do this combo again. It feels really solid. I have not installed the coupler yet.
3literpwr 11-01-2022 01:13 PM
Been having some issues with my Numeric on my SC. Seems like there are people saying that the 5th gear lockout needs to be on the driver and passenger side. Who has the latest here?
Tremelune 11-01-2022 02:08 PM
It depends on whether your transmission is a 901 or a 915. The lockout needs to be on the side reverse is on.
3literpwr 11-01-2022 04:16 PM
People seem to say the lockout needs to be on passenger and driver side for the 915 in this thread...Wondering if they actually have the shifter or are referencing the stock location on the stock shifter? That would be apples to oranges in this situation.
On a stock shifter, the reverse lockout is on top of the shifter and clearly is on the reverse side of the housing...but, this acts on the shift rod ABOVE it's pivot point. On the Numeric, the lockout is below the pivot and acts on the opposite side. If you mount the lockout on the passenger side for a 915, the lever moves away from the lockout when going into 5th / R.
quickxotica 02-27-2023 09:30 PM
This is correct. I have the Numeric on my 915 and the lockout works (after I switched it to the driver's side).
Flojo 02-28-2023 04:20 AM
Im still absolutely delighted about it.
Same es friends who bought it due to my recommendation.
Great shifter!
Flojo 03-13-2023 02:42 PM
You guys have issues with Numeric Racing?
Ordered and payed a 915 set on March 1st.
Haven’t heard back at all.
No reply to my email March 10 asking for shipping updates.
Messages via Instagram are on read but no reply either.
Frustrating.
edit: resolved. Shipping info received
Jjm4life 04-19-2023 05:58 PM
quesiton about how this shifter should feel. i think might is a bit tight? needs very high effort to shift, however the shifts are very postiive and the throws are very short. i like how the linkage feels and its very direct. just wish it was a bit more.. fluid? i hope that makse sense. overall really enjoying the first few miles.
i should add that it was installed along with a new motor, clutch etc. so i have no idea how to adjust it or if its even adjustable in that sense.
jrwilson 04-20-2023 03:48 PM
This is the nature of the 915 transmission - all the "feel" is on the transmission end, not the shifter.
Tony V 04-20-2023 04:28 PM
jJim,
I installed the Numeric in my '74 Targa. I had a Rennshift previously and once the Numeric was installed, it felt stiff. It was difficult to move. Last week I took the shifter off and discovered that I had installed the bracket that holds the shift rod bushing incorrectly. Hate to admit it but I installed on the inside the tunnel instead on on top. Changed it and it was an amazing change in feel. Was going to keep my dumb mistake to my self but thought I'd share in case the same was done to yours. Depending on if you have a console, you pull the boot up and remove the bolts holding the shifter down. Lift it out and see if the bracket is installed on top of the center tunnel.
Their optional shift extension also helps. I went with the longer one.
Tony
WCN621 07-01-2023 11:54 AM
I’ve had and enjoyed the Numeric shifter in my G body for well over a year, but just before my last rally, it went out of “alignment”. The lockout is on the driver’s side and has worked flawlessly, and then stopped.
Reviewed the videos again and noted the adjustment nut and threaded inset hex bolt for correction. When I went to do the adjustment, the threaded hex bolt is not inset and I don’t have the ability to correct. I contacted Numeric before the rally and had no answered phones or returned calls. Ended up scratching reverse far more than I wanted during the rally and a missed shift to avoid scratching again. I have gotten rather frustrated after it working so well.
After multiple calls and initiating “chatting”, I have not received ANY response to my efforts from either person at Numeric. Even spoke to a vendor about the issue and they said their customer service is not something to get excited about.
Well that doesn’t solve my issue. I’m wondering if I bought one of the earlier gbody models that may have not had the inset screw, but all I want is to have this back to operating like it had. Has anyone else had this issue, and did Numeric respond to correct? Thanks.
Tony V 07-01-2023 12:40 PM
Ordered one when they were first offered. Have never received any response to problems or inquiries. Shifter is terrific but there is no Cust Service. I’ve never got my reverse lockout to work even after moving it to the drivers side from the passenger side as it was installed by the manufacturer. The YouTube video is laughable. Filled with incorrect information. Too bad they don’t reply. Hate to think how a warranty issue would be handled.
Tony
texasroads 07-02-2023 02:20 PM
are there any information available about Numeric planning to make a shifter for g body g50 transmissions (1987-1989)? thanks!•
Jjm4life 07-02-2023 06:03 PM
Tony
also having issue with reverse lockout. i grabbed a bunch of reverse downshifting from 5th last week.
generally, im happy with the shifter. height is great. throws are the right length. i seem to have issues requiring a lot more effort than i would expect to get out of gear, but it goes through nuetral and into the next gear smoothly.
also of note, i broke the set screw for the shift knob
Ryan_Cunningham 07-21-2023 11:51 AM
Anyone have a rough idea of the time commitment to get the NR shifter and couple installed including carpet and console removal? I’ve done it on my 930 equipped car but it really doesn’t have an interior.
Have to determine if it’s worth undertaking with a five year old and one month old when I only get about an hour at a time to do work.
http://forums.pelicanparts.com/uploa...1689969085.jpg
EauRouge 07-22-2023 11:10 AM
It has been a while since I did the install so my memory is fuzzy. I think it took me ~3-4 hrs as I took my time since it was my first time removing the shifter. I had a lot of trouble getting the NR shift coupler lined up to my liking.
Ryan_Cunningham 07-22-2023 02:05 PM
I figured it’d be somewhere in that time frame but hearing someone else corroborate it helps me out - Thanks.
I just got the car back on the road today after spending a week back dating the heat and installing strut braces so I’ll probably drive it for a week or two then go for it.
AlKidd 07-22-2023 05:09 PM
That is kind of a while your in there question too. Hows your bushings etc. How good are you at setting up your shift coupler? A lot of variables to your question.
Ryan_Cunningham 07-23-2023 09:09 AM
I have new bushings which will go in with the shifter and new coupler.
I set up my 930 shifter and coupler a few months ago after dropping and reinstalling the engine on my 72 so I'm decently familiar.
