it would be nice if they offered one that looked a little closer to stock
I installed this Numeric shifter and coupler in my stock ’85 Carrera about a month ago. I’ve waited until now to write about it, to give it a clear-eyed appraisal.
TLDR version: It’s much more precise than stock and I intend to keep it, but I can’t say it’s better or worse than the WEVO or JWest equivalent products. The Numeric does what it says on the box. It takes real patience to properly adjust the coupler and reverse lockout. The throw-reduction is significant, making it obvious to anyone it’s a non-stock shifter. The solid coupler introduces a very slight gear-whine into the cabin. Full version: I bought the Numeric, in part, because I have their 997 shifter in my 997.2 and love it. I also previously had a Wevo 915 shifter in my Spec911 racecar, which functioned perfectly fine. I chose the Numeric over the Wevo or Jwest for this car (the ’85) because I was curious about their new design and wanted a black, non-aluminum knob. The Numeric shipped quickly and the component parts all appear well-made. Out of the box, my only gripe was my unit arrived with the reverse lock-out installed on the passenger-side (a'la 901), despite my paperwork reflecting that I’d ordered a 915 version. Easy enough to transfer it over to the driver’s side (flipped), but I’m glad I noticed this before getting too deep into my install or it would’ve been a pain to R&R the whole thing. Numeric’s install video for this product is helpful but imperfect. It deserves to be re-shot with an error-free script & much better lighting (not a flashlight in a dark garage please). The comments in this thread about how to initially align the coupler were also helpful. I first installed the shifter alone, without Numeric's coupler. My stock coupler is probably original to the car. As you’d expect, this resulted in short shift throws that still had about a half-inch of longitudinal slop in the lever. Some may prefer to stop here. A week later, I went ahead and swapped in the Numeric coupler. Like any coupler swap, this requires patience to get right. Tiny (and I mean TINY) changes in the positioning of the coupler translate into major changes at the lever. You need to drive around with two 13mm wrenches in your pocket and leave the coupler-cover and shift-boot off so you can adjust things repeatedly until all three of the following are true: 1. each gear is easily found, 2. the self-centering springs perfectly align with the 3-4 plane, and 3. the reverse lockout snaps into place every time when selecting 5th. If you do all that, the result is very good. If not, you will likely suffer poor gear selection and embarrassing scratches (of reverse) when trying to get 4th. Keep adjusting! Now that I’ve got mine dialed-in, I can honestly say this mod is a fun, confidence-inspiring upgrade over stock. On the road, every selection of 5th gets an audible, reassuring ‘Click!’ as the reverse lock-out does its job. And I no longer have any doubt what gear I’m selecting. The additional gear-whine noise from the solid coupler is noticeable even with the stock rubber boots and cover in place, but not obtrusive. I'd say it's 10% of what the noise of straight-cut gears in an old Chevy truck sound like, or, for a better point of reference, it’s quieter than switching to ‘semi-solid’ motor mounts. Sensitivity to noise is personal, though, so YMMV. If I had to do it again, I’d order the 2.5mm spring to further increase the self-centering. I like the tall extender and wouldn’t want it any shorter. The knob is big in the hand (maybe a tad too big? maybe not "OEM+" enough?), but it feels good and doesn’t get hot or cold, ever. As you can see in this pic, the i-beam shape of the lever is entirely hidden by the stock leather boot so it’s a moot point, for those worried about aesthetics. Thanks for reading. PM me if you have questions. http://forums.pelicanparts.com/uploa...1647636165.jpg |
Mine arrived with the reverse on the opposite side as well and I sent a note to Numeric suggesting that whoever was doing their quality control or order review needs to be on the alert for it and didnt even get the courtesy of a reply. Unfortunately I spotted it after I had installed the shifter in the car. Another thing to note is that their knob only fits the shaft extenders. I couldnt find it noted anywhere on their web site. I too have a custom knob and had a machine shop turn down the long extender to stock size.
Thanks again, Dennis |
Mine is installed, but I’m waiting on my first start. I also have Wevo Gate shift in the gearbox. Will take some adjustment and getting acclimated to.
Video of its sound. https://youtu.be/CHdfclbKtNg |
I had rebuilt my coupler but figured there was enough variation between the shifters that old and new wouldnt match so went at it. Someone posted in this thread to put it in 3rd and then just adjust f/r. It save a lot of time. Getting it to hit their R lockout when coming out of 5th is the only tricky bit after that. Id hate to think I have a 6 speed
What side should reverse lockout be?
Working on this install now. I’ve watched the video and read this thread. I’ve seen some comment the reverse lockout is installed on the wrong side for a 915 transmission.
What side should it be on for a 915 transmission? Mine currently is on the 5-R side of the shifter tower so I’m getting lockout on the 1-2 plane while towing the gears. Is it correct to assume I need to re-install the lockout on the driver side of the shift tower? Silly question but in the video Numeric did it appears it’s on the 5-R side but I just can’t see that making sense. |
Thanks! Will uninstall and try to get this sorted tonight. |
Mine was delivered, in December of 2021, on the wrong side too. I sent them a note on it but didnt get any response. Disappointed because its a great shifter. I feel these guys may be a one hit wonder.
http://forums.pelicanparts.com/porsche-911-technical-forum/1117369-ultimate-shift-rod-bushing.html |
I've always liked this video for adjusting the coupler:
https://www.youtube.com/watch?v=8JDlBKERL3w&ab_channel=JWestEngineering |
I hate that interface with the soft plastic ball cup bushing. I suppose the only way to make that a U joint would be to raise it out of the tunnel. Would that even work? If the shift rod were straight all the way back, I guess you could spin the shift rode and thread it into a joint. Edit: No, that wouldn't work.....when the lever goes to the left, the shaft turns to the right. |
I installed mine a few months ago after letting it sit on the shelf for a year. Was frustrated with the video and was going to sell it. Happy I gave another try. Got the extension which helped with the feel. Haven’t gotten the reverse lockout to work. When looking at the factory shifter, the reverse lock is on the passenger side as is the Numeric. Can’t see how it could work installed on the drivers side??
Tony |
Nope. I haven’t done any more fiddling with the reverse lockout. Gave up and am just careful when downshifting from 5-4. My original 915 shifter had the reverse lockout on the passenger side. My J.West was also in that side. Really can’t imagine it would work on the drivers side. With the other shifters on the right, I’m pretty sure it’s supposed to be on the right side.
It doesnt work on the drivers side. As I and others posted above, mine arrived installed on the wrong side. Its easy to move to the passenger side of the shifter. Dont risk hitting R from 5. Just move it.
