Fred: Yes stuff is close to high voltage, but not too close. The epoxy is rated for 450v/mil thickness and I am allowing 150 mils clearance minimum.
No, those are not fiber optic. I made the equivalent of 60kv spark plug wires with an OD of just 1/8". These are the output wires. And they are not shielded.
Old 05-09-2021, 06:43 PM
Jeff Alton's Avatar
Originally Posted by winders View Post
I suppose this is to suggest that MoTec could not have figured out how to do this properly sometime in the intervening 29 years....
With the MoTec M130, I can see the knock on a screen as it is happening while tuning. I can set the thresholds of when, what type (timing or fuel or both), and how much intervention is applied on a per cylinder basis. I can log these interventions so they can be tracked.
Scott, are you running 1 sensor per bank on the factory bridge or 6 sensors?
Cheers
www.turn3autosport.com
Old 05-09-2021, 09:47 PM
Racer
winders's Avatar
Originally Posted by John at J&S View Post
But one may ask a question, why do you have to intervene at all? That's the brute force approach.
Nominally, we don't have to intervene. We aren't stupid.
We tune the car so there is no knock in typical operating conditions with race fuel. But, we use the knock sensors in case there is bad/incorrect fuel or the heads get too hot or some other event (e.g., ignitor failure, broken coil wire, etc.)occurs that causes knock. We can detect the knock and increase fuel, back off timing, or both so there is no more knock. If we get x amount of knock events, we display a warning on the dash. Heck, we even put the engine in a limp mode if things are really bad.
It's easy to look at the ECU logs to see if we are getting any knock events under nominal conditions. If we did, we would retune the car so we did not. So far, we aren't getting knock events under nominal conditions. so we are comfortable with our tune.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 05-09-2021, 10:21 PM
Racer
winders's Avatar
One sensor per bank is all the Motec M130 system needs assuming you are using a crank position sensor (60-2 in my case) and a cam position sensor.
Scott Winders
PCA GT3 #3
Old 05-09-2021, 10:23 PM
Still, I'm completely confused. What is the purpose of the extra HT wires? Output to what? What else could possibly need high voltage other than the spark plugs. There are easier and lower voltage methods to analyse the spark quality if that is what the purpose is. It looks awfully delicate to me for something meant to go on a race car (or any car really). Maybe I want to know too much and out of ignorance asking dumb questions. I'm not a racer. Fred
Old 05-10-2021, 04:23 AM
Fred, I sent a you a PM a couple of hours ago.
Old 05-10-2021, 04:51 AM
Thanks John, Got it! Fred
Old 05-10-2021, 06:40 AM
Functionista
manbridge 74's Avatar
Designed at the World Headquarters of J&S Electronics. A spare bedroom in our condo.
I try to plug my stuff from time to time on different forums. I know I am often seen as an annoying guy hawking my wares, but I have invented a lot of cool ignition stuff. It's more "look what I did" than an actual sales pitch.
Shirley died recently from cancer. I found a video on her phone she made in 2016 and put it on youtube. It shows me testing an earlier version of the above system. I had to set the project aside the last three years while I cared for her:
https://www.youtube.com/watch?v=u0b3mFWPIqI
My condolences to you about your wife.
I remember you from other boards in the the early 2000s. Kind regards….
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-10-2021, 06:29 PM
Jeff Alton's Avatar
Old 05-10-2021, 10:26 PM
Thanks very much, Jeff. We were married 46 years.
What other forums? Honda, Subaru, Miata?
Old 05-10-2021, 11:21 PM
Functionista
I believe the MR2 forum as I was big into Alltracs which shared the 3SGTE engine...
Jeff
74 911, #3
Old 05-11-2021, 04:20 PM
