Long Term Storage-Fuel
After draining the fuel tank, should I start the car & run the engine until it stalls to make sure no gasoline is left to gum up my injectors? TIA
Old 07-05-2021, 03:39 PM
HarryD's Avatar
Check post 20 of this thread. http://forums.pelicanparts.com/porsche-911-technical-forum/183215-winter-storage-checklist.html
Ignore Grady Clay (RIP) at your own risk.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-05-2021, 03:51 PM
Our winters are usually not long periods of no activity, so I never do a full "winter storage" preparation. I can easily get 100% gasoline, so I fill the tank and add the Stabil and drive it far enough to get things warmed up to operating temperatures.
I never go more than three months before driving it again.
Instead of running it dry and possible damaging the fuel pump, I would find some racing fuel, or even avgas if you can't find alcohol free gasoline. Just a few gallons and the Stabil and you will be fine. If you are going for long term storage, of more than a year, then for certain follow Grady's instructions in the thread posted above.
You did not define what your long term storage time frame was. 3 months is one thing, 3 years is way different for needed preparation.
Old 07-06-2021, 08:03 AM
HarryD's Avatar
Glen,
Totally agree. If storage is less than 3-4 months, other than some fuel stabilizer and adding some extra air to the tires, I would just throw a cover over the car and move on.
Harry
2020 MB E350 4Matic
Old 07-06-2021, 09:28 AM
GG Allin's Avatar
I read all that, I think I'll just sell my car.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 07-06-2021, 09:34 AM
Brew Master
cabmandone's Avatar
How long are ya talking about storing it?
Nick
Old 07-06-2021, 10:19 AM
Back to the original question. If you're storing the car for a season (like winter) I believe the SOP is to fill the tank with fresh gas with a fuel stabilizer. Then run the car a few minutes to pull the fresh gas/stabilizer mix thru the system. Be advised most fuel stabilizers are only good for about a year according to their labels. If you're storing the car for a few years, then draining the system might be the way to go.
Old 07-06-2021, 09:01 PM
As the OP, let me answer the time horizon- I'm looking at a year or two of not using the car.
Old 07-07-2021, 07:40 PM
HarryD's Avatar
1-2 years often becomes much longer. Check Grady's list. It will make you restart more successful.
Harry
2020 MB E350 4Matic
Old 07-07-2021, 08:00 PM
Harry, I have & will follow Grady's list. Thank you.
Old 07-08-2021, 01:16 AM
