Antomero's Avatar
Originally Posted by 3literpwr View Post
I'm currently waiting to get my pedal assembly and handbrake back from Tuthill in the UK. They are also supplying the 4 pot calipers they run on the gravel and safari cars. They are pretty simple and run stock Carrera rotors when not on tarmac. Spring rates are 19mm front and 27mm rear and NO bars.
Looks awesome dude!
Old 03-30-2022, 11:49 AM
(man/dude)
Jonny042's Avatar
It will be ARA (formerly Rally America) in 2WD.
Right on. Looks like a great series.
You might already be on top of this, but 915 gearboxes are easy and affordable to re-gear into really nice close ratio boxes. Would be a huge advantage for a gravel rally car.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-30-2022, 05:06 PM
Currently geared to SCRS ratios with a Kaaz LSD.
Old 03-30-2022, 07:10 PM
Pelican Parts Vendor
BRAIDusa's Avatar
Great job Larry. I'm approaching 9 years on my Quattro build and seing this fire up is inspiration to get it done.
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 03-31-2022, 05:06 AM
(man/dude)
Jonny042's Avatar
You know, it's almost like you know what you're doing
Curious about the engine combo - compression, heads/ports and cam profile? Are those 46mm PMOs?
That's going to be a really fun car, I'm envious! Looking forward to the in-car video.
Old 03-31-2022, 06:41 AM
Now I need to sort a dyno and tuner in SoCal.
Old 03-31-2022, 06:45 AM
Engine is a 3.0 with 10.6:1 JE pistons, large port & flow benched heads, DC60 cams, JB 12 plug and some other bits. PMO’s are 46mm that William Knight set me up with years ago. Currently on SSI as I want heat. Had Dansk muffler on for start to keep it quiet. Exhaust might be tricky as rally rules require a cat. Have a Motorsport cell and need to fab into some sort of 2 to 1 system.
Old 03-31-2022, 06:47 AM
https://youtube.com/shorts/hljxOHzhleQ?feature=share
Old 03-31-2022, 06:56 AM
Hi, did you change the gearing at all in the transmission? Beautiful car!
Old 02-03-2023, 07:38 PM
Awesome build !!!
Old 02-04-2023, 12:04 AM
Yes, the gearbox has SCRS gearing (2,3,4,5th) Kaaz diff and Wevo gateshift.
Old 02-04-2023, 08:15 AM
Exited to see how this goes. Would love to hear more about the ExeTec setup you have as I have been contemplating the same... Great looking build!
Old 03-19-2023, 11:27 AM
Old 03-19-2023, 07:57 PM
Wow!! Sounds amazing!!!
Old 03-19-2023, 08:14 PM
Hell yeah!
Old 03-19-2023, 08:34 PM
really nice build.... i'd be scared to .... introduce that into the wild so to say, ha!
Old 03-20-2023, 05:28 AM
To answer the question about the dampers, they seem good and i've done a bit of tuning with them. The main issue is that the rebound adjuster is BELOW the balljoint. This means, that rebound adjustments only happen with lifting the strut off the pin. A total pain. Also, haven’t competed with the car yet, as my wife / co-driver being pregnant and the first event (gorman rally) landed on her due date. I think i'm gonna need to find another navigator when I have time.
Old 03-20-2023, 07:09 AM
Old 03-20-2023, 07:12 AM
That is an interesting design "feature". How well do they do going from Tarmac to Gravel? Do you find that you have good feel on both? Or compromising one for the other. Excited to see some videos of this one! Stage Rally has always been a goal/dream of mine! Excited to see someone doing that in a 911 in the US.
Old 03-20-2023, 04:15 PM
Love the simplicity of this build. How light did you get it down to, did you ever weight it?
Old 03-26-2023, 10:32 AM
