911 mirror wire end connector
I want to change the exterior mirror base gaskets.
Is there a break in the wires inside the doors or do I have to unplug the connector ends (PICTURED) from "somewhere" inside the body, beyond the door jams and feed it back out through the door and out?
Old 07-15-2022, 11:47 AM
You have to determinate the wires. There are terminal kits that will help.
Edit: Here you go: https://www.amazon.com/Lisle-57750-Wire-Terminal-Tool/dp/B007WQQHA2/ref=asc_df_B007WQQHA2/?tag=hyprod-20&linkCode=df0&hvadid=241896598945&hvpos=&hvnetw=g&hvrand=12302932518055892549&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9016798&hvtargid=pla-350389673975&psc=1
1982 911SC
Old 07-15-2022, 12:23 PM
Hi David,
Not sure what you are showing me..please read my post again...want to know if I have to feed the wire with the connector end back out of the door or there is a break in the wires where I can simply just disconnect rather than feeding a lot of wire out.
thanks
Old 07-15-2022, 12:29 PM
ROW '78 911 Targa
timmy2's Avatar
You have to take the wires out of the connector to remove the wires from inside the mirror.
Then you can install a new gasket.
The wiring in the door doesn’t come out.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-15-2022, 11:45 PM
You can remove the wires from the terminal. Another recent thread shows the tool.
Old 07-16-2022, 08:03 AM
Ok, got it! Anyone know which tool end works with this particular connector? is there a tool I can buy at a local store? Harbor Freight? Auto Zone etc?
Old 07-16-2022, 08:33 AM
ROW '78 911 Targa
timmy2's Avatar
Google Lisle terminal tool kit.
Not sure where you are, so don’t know what stores you have available, but lots show up.
It will be one of the round hollow pieces that are the tightest fit as you slide it over the terminal and push the terminal out.
Be sure to mark each terminal and wire to go back together right.
You will have to carefully get the locking tabs lifted to engage again when done. So they will go back in their holes and stay.
I use an exacto blade for that.
Dennis
Old 07-16-2022, 09:53 AM
im in NJ
would it be easier to unscrew at the mirror and remove the wiring from the inside rather than disconnecting the connector and feeding the wire in and out. looked at it..seems tight.
Old 07-16-2022, 11:32 AM
ROW '78 911 Targa
timmy2's Avatar
Read this thread, good photos.
http://forums.pelicanparts.com/porsche-911-technical-forum/661069-i-thought-side-mirror-removal-easy.html
Dennis
Old 07-16-2022, 11:37 AM
need to open it up!
Thanks again...I will open the mirror to see what Im dealing with. Its crazy cause I know Ive change the gasket before and do not remember having to pull the wiring out of the body cut any.
Thanks again.
Old 07-16-2022, 12:04 PM
Cut or NOT to cut??
Obviously I can NOT simply disconnect to separate the mirror base from the car..looks like my only 2 options are disconnect from inside the body and feed wires out then back in (nightmare-ish!) OR cut and reconnect at the mirror. any thoughts?
Old 07-18-2022, 09:17 AM
That white plug is two-piece. You can pull it out a bit and disconnect the wires from the plug on the body side.
Use the terminal kit I posted above.
Edit: The terminal kit goes in the holes on the plug to depress the tabs on the wires, then you pull out the wires.
Double-edit: You cannot do this without a terminal kit like the one linked.
1982 911SC
Old 07-18-2022, 10:06 AM
Thank you again David Inc. Yes, I was able to separate the white plug! Didnt look like it worked that way. Now I can go ahead with my project. Thanks!!
Old 07-18-2022, 11:05 AM
You will know that if you cut any wires, you did it wrong :-)
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 07-18-2022, 12:11 PM
Targa_PB_78_SC
mike sampsel's Avatar
Take many pictures of the wire locations before you disassemble.
Note the orientation of the “v” in the plug, and I
Would use a black marker line with the “v” to help picture orientation of
Those pesky wires!
BareRearedRookie
Old 07-18-2022, 01:46 PM
didnt work.
https://imgur.com/xCri5vQ
Old 07-23-2022, 07:49 AM
Targa_PB_78_SC
Did you look here?
http://forums.pelicanparts.com/porsche-911-technical-forum/1022018-flag-mirror-wires-tool-help.html
If yours are like mine, it takes a twist with a small needle nose to unlock the wires. I took off my mirrors for painting. Like for you, the tool did not work for me. Likely depends on the year of your car though. Another tool is mentioned in the link.
BareRearedRookie
Old 07-24-2022, 04:54 AM
ROW '78 911 Targa
timmy2's Avatar
Parts for these beasts for future reference..
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1123411-do-you-have-conncetor-pins.html#post11753734
Dennis
Old 07-26-2022, 06:44 PM
Tags
mirror connector , wiring
