My other ride is a C-130J
The Dual Extruder printers interest me, but I wonder if two filaments compromises the strength of the final product.
What size platform is ideal? Too often I want to print something only to find out I’m 1 cm short on my bed.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Just printed those door striker pieces on my credulity 3d cr10 mini. I am however far from a pro.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Drive it like u stole it.
I started with an Ender3 then slowly upgraded a few bits. The one big one is the hot end so that I could print using ASA material. ASA will withstand the sun and heat of the car. There are guys that have printed intakes with this material. The direct drive hot end also allows you to print using TPU flexible material for grommets and such.
I added this hot end: https://amzn.to/3QpZVn3
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Nice! What settings did you use?
Also - strongly recommend carbon reinforced PLA but it's really hard on your tips and so if you do go carbon, grab an extra bag of tips. |
For general parts prototyping what size bed is recommended? Will a small 180x180cm bed work?
Here are the parts that I've made.
Bushing installation tool for the front control arm rubber bushings: https://www.thingiverse.com/thing:5449052 P207 Z-Block for mounting a dial indicator when setting cam timing: https://www.thingiverse.com/thing:5449059 Mount for a 52mm gauge in the clock location: https://www.thingiverse.com/thing:5449066
'86 Porsche 930 '04 Bmw M3 '65 Ford Mustang |
Yeah this works fine and if you're doing much larger parts, you just cut them up in fusion and add keying to the parts to align them when rebuilding the printed parts.
@jmd88 thank you, gonna do a bit more research before buying a printer
What did you print the control arm removal tool with?
Can you post a link to those cup holders please?
STL's
I have added a few stl's in the download section of my website.
Downloads – Floyd Design More engine assembly tools to come, just need to update.
Outlaw .... by definition ..... does not follow rules well www.FloydDesign.ca https://www.youtube.com/watch?v=sV5aIALWlG8 |
Elephant racing supply two bushing tools with their control arm bushings. One is conical and goes in the end of the control arm to help the bushing expand and slide on. The other maintains the proper depth of the bushing in the outer cylinder.
This video shows both parts at about 1min 15es. https://www.youtube.com/watch?v=MX5jgsMiuFw&t=4s In the picture I posted, the conical tool is inside the bushing being installed on the left side of the photo. You can just see a thin white circle on the inside of the bushing. The white part between the bushing the clamp on the left side of the picture is the other part of the installation tool.
Tools
![]() Cylinder hold down nuts, simple version with drop in hex nut, stl on my website Updated version with heat sink thread inserts, Fuch Nuts, cylinder hold down ![]() ![]() Piston oil squirter test tool. It is a bit distorted in the picture, sat it down next to a hot item and the printer needs a tune up, not a great print but it works. Chain tensioner, Cir clip installation tools , two different cir clips, two tools required Chain tensioner, bleeding depth tool P214B, see http://forums.pelicanparts.com/porsche-911-technical-forum/744845-pendulum-outlaw-build-adventures-misadventures-16.html ![]() Connecting rod holding tool, P221 Chain holding tool, P222 ![]() Yoke engine stud spacers ![]() ![]() ![]() Engine case stand ![]() ![]() Shift knob stand and installation tool, when using a new shift knob crush sleave it is a bit hard to push on. Put tool on top of the knob and lightly tap on with a hammer. Most tools stl’s will be added to my website download section on the next update, if you need it sooner send an email. I have an Creality Ender 5 Plus, picked for its print bed size 350 mm x 350 mm, good community support and upgrade parts availability. In the process of adding a Mosquito clone hot end and an enclosure to be able to print ASA and PA CF. I bought it to develop some commercial parts to be printed on commercial printers and also a little give back to the community, the tools. Sometimes it is hard to get some time on the printer at home, seems to be too many colorful MCM plant pots being printed. Hence my multi color cylinder hold down Fuch nuts.
Wow awesome job Tom
More Tools
Thanks Nditiz1
![]() ![]() Fixture to hold the flywheel on a rotary table to hone the surface. ![]() ![]() Dial indicator bridge, to locate TDC to check the deck height.
fun to see my throttle bushings in here hahah
they work great |
kinda slow
Incredible stuff. Living in the future ain't so bad sometimes.
1983 911 SC Coupe |
