DIY 3D Printing Tools and Parts Thread
Hello Pelicans, many of us have 3D printers as they have become cheap to buy and easy to operate. I would like to start this thread for folks to share their designs, ideas and files for others to use. It will save everybody time and therefore money.
I hope to get some participants. Greetings, Daniel |
I have been looking at cheap 3D printers and I wondered if I bought one where would I find the 3D build files. There are several vents that have been made by Pelicans for the CR Electrocooler AC system. Maybe they will post their files to this thread and all the files would be accessible in one place.
Let me load the ones I have to thingiverse this week. I am trying to get the slicing correct for the PETG as my first set of PLA vents warped when using my heat last winter.
Pat - I still owe you a set. I'm actually printing them now. |
I have a bunch that I can load into thingverse.
Last winter I floated the idea of building a Porsche 3d printed file repository but it was received with crickets... |
Hey Showdown, glad we share the same thought. We can use this Thread to have discussions on new printed components, also requests that some members maybe have but use thingverse for holding the files?
Daniel |
Ha! The Porsche wall letters are mine! I have a few more interesting designs.
Very keen on a repository for 911 files. I'm pretty new to 3D printing, but made this up last week for my 911, its mounted to the original center console mounting holes on my tunnel with 2 screws (107mm c2c) I'm not sure if this is universal on all models or someone had drilled mine previously for the console. It may or may not be of use to others?
https://i.ibb.co/Nt3bNrd/Capture.jpg https://i.ibb.co/ys2GT2t/20220730-180840-edit.jpg |
That's dope. Subscribed.
Thanks |
How about some door striker parts? I’m thinking about buying a 3D printer what would you guys recommend for making car parts?? Et. I’m not into Marvel action figures.
Dash pull knob buttons for repurposing to control AC or an oil cooler fan:
https://www.thingiverse.com/thing:5447649 Classic Retrofit AC parts: https://www.thingiverse.com/thing:5447651 Hand throttle collar stop for throttle rod (NLA): https://www.thingiverse.com/thing:5447656 |
Here are my Door Buffers - I've got about 10K on them and they are still fully functional. These are 100% original design, model, test by me. https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...pg?format=500w https://images.squarespace-cdn.com/c...EG?format=500w Love this group!!! More to come. jmd |
I made this equalizer box for my period correct blaupunkt system. I also incorporated a couple of USB ports at the back to power the phone.
https://i.imgur.com/uRUbq0B.jpg It’s a no-drill install that gets it under the dash and gives a tidy phone input for the rennline phone mount. The equalizer used to be on the console but I wanted to mount a center AC vent, hence the box. https://i.imgur.com/dHuhz0x.jpg The phone wire routes through the ashtray, so it can be tucked away when not in use. There’s a second charger wire in the ashtray for passengers. The entire system uses Bluetooth (hidden behind equalizer box) to transmit through FM. It works great except for the hiss of static before the Bluetooth cuts in. Figuring out how to maybe time delay the amp on power up to fix that, or something similar. |
@jmd88 - thanks for this! I was just looking up acquiring new ones since they are crumbling on my coupe. It doesn't look like you can buy them separate. Firing up the printer now. Can you check the link to your files? I'm getting a 404 on thingiverse.
Which printer should I buy???
I'm running a Creality CR10-Mini and it seems to be working fine. I need to convert my prints from PLA to PETG, but so far with PLA it has been really good. I think I paid around $200.
I just created my thingiverse account so it might still be propagating.
Does this work: Link to .STL if not, DM email and I'll send it over. Quote:
Hope that helps. |
The Dual Extruder printers interest me, but I wonder if two filaments compromises the strength of the final product.
What size platform is ideal? Too often I want to print something only to find out I’m 1 cm short on my bed. |
Just printed those door striker pieces on my credulity 3d cr10 mini. I am however far from a pro.
http://forums.pelicanparts.com/uploa...1659648930.jpg |
I started with an Ender3 then slowly upgraded a few bits. The one big one is the hot end so that I could print using ASA material. ASA will withstand the sun and heat of the car. There are guys that have printed intakes with this material. The direct drive hot end also allows you to print using TPU flexible material for grommets and such.
I added this hot end: https://amzn.to/3QpZVn3 |
Nice! What settings did you use?
Also - strongly recommend carbon reinforced PLA but it's really hard on your tips and so if you do go carbon, grab an extra bag of tips. Quote:
For general parts prototyping what size bed is recommended? Will a small 180x180cm bed work?
Here are the parts that I've made.
Bushing installation tool for the front control arm rubber bushings: https://www.thingiverse.com/thing:5449052 P207 Z-Block for mounting a dial indicator when setting cam timing: https://www.thingiverse.com/thing:5449059 Mount for a 52mm gauge in the clock location: https://www.thingiverse.com/thing:5449066 |
@jmd88 thank you, gonna do a bit more research before buying a printer
What did you print the control arm removal tool with?
Can you post a link to those cup holders please?
You can see just the edge of the conical tool inside the bushing. http://forums.pelicanparts.com/uploa...1659817450.jpg |
STL's
I have added a few stl's in the download section of my website.
Downloads – Floyd Design More engine assembly tools to come, just need to update. |
This video shows both parts at about 1min 15es. https://www.youtube.com/watch?v=MX5jgsMiuFw&t=4s In the picture I posted, the conical tool is inside the bushing being installed on the left side of the photo. You can just see a thin white circle on the inside of the bushing. The white part between the bushing the clamp on the left side of the picture is the other part of the installation tool. |
Tools
http://forums.pelicanparts.com/uploa...1660346926.jpg
Cylinder hold down nuts, simple version with drop in hex nut, stl on my website Updated version with heat sink thread inserts, Fuch Nuts, cylinder hold down http://forums.pelicanparts.com/uploa...1660346926.jpg http://forums.pelicanparts.com/uploa...1660346926.jpg Piston oil squirter test tool. It is a bit distorted in the picture, sat it down next to a hot item and the printer needs a tune up, not a great print but it works. Chain tensioner, Cir clip installation tools , two different cir clips, two tools required Chain tensioner, bleeding depth tool P214B, see http://forums.pelicanparts.com/porsche-911-technical-forum/744845-pendulum-outlaw-build-adventures-misadventures-16.html http://forums.pelicanparts.com/uploa...1660346926.jpg Connecting rod holding tool, P221 Chain holding tool, P222 http://forums.pelicanparts.com/uploa...1660346926.jpg Yoke engine stud spacers http://forums.pelicanparts.com/uploa...1660346926.jpg http://forums.pelicanparts.com/uploa...1660346926.jpg http://forums.pelicanparts.com/uploa...1660346926.jpg Engine case stand http://forums.pelicanparts.com/uploa...1660346926.jpg http://forums.pelicanparts.com/uploa...1660346926.jpg Shift knob stand and installation tool, when using a new shift knob crush sleave it is a bit hard to push on. Put tool on top of the knob and lightly tap on with a hammer. Most tools stl’s will be added to my website download section on the next update, if you need it sooner send an email. I have an Creality Ender 5 Plus, picked for its print bed size 350 mm x 350 mm, good community support and upgrade parts availability. In the process of adding a Mosquito clone hot end and an enclosure to be able to print ASA and PA CF. I bought it to develop some commercial parts to be printed on commercial printers and also a little give back to the community, the tools. Sometimes it is hard to get some time on the printer at home, seems to be too many colorful MCM plant pots being printed. Hence my multi color cylinder hold down Fuch nuts. |
Wow awesome job Tom
More Tools
Thanks Nditiz1
http://forums.pelicanparts.com/uploa...1661090341.jpg http://forums.pelicanparts.com/uploa...1661090341.jpg Fixture to hold the flywheel on a rotary table to hone the surface. http://forums.pelicanparts.com/uploa...1661090341.jpg http://forums.pelicanparts.com/uploa...1661090341.jpg Dial indicator bridge, to locate TDC to check the deck height. |
fun to see my throttle bushings in here hahah
they work great |
Incredible stuff. Living in the future ain't so bad sometimes.
