Hello Uro,
Do you hove any info on your rear quarter window seals? Both glass to frame and window to chassis. Thanks for the update for the stock of the windshield seal.
Paul 83 SC The Herring |
Pelican Parts Vendor
Hi Brookieslayer, we recently redesigned Quarter Window Seals for 1965-1977 coupe with hinged window (901 543 901 20, 901 543 902 20), and currently have several pair out for fitment testing. The new version is thinner and the profile has been adjusted to better match the body contour. The batch code for the new version is 9440 or higher.
Our Quarter Window Seals for 1978-1987 coupe with stationary glass are 911 543 035 01 and 911 543 036 01.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 11-17-2022 at 10:27 AM.. |
Does this seal fit a 1973 911 and is it now in stock at Pelican?
I'm guessing anyone that purchases as a direct ship from you all will get this latest version
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 11-18-2022 at 09:19 AM.. |
Pelican is currently working on getting Windshield Seal 911 541 225 03 working in their catalog, thanks for your patience guys! They hope to have it resolved on Monday.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 12-15-2022 at 02:14 PM.. |
Hi everyone, Pelican has the latest-version windshield seal live on its website, but due to interchange part number challenges it won't come up if you search for the exact OE number. Pelican's part number for our seal is 911-541-225-04-M253 (dashes are required, and M253 is their code for URO).
Direct link: https://www.pelicanparts.com/More_Info/91154122504.htm?pn=911-541-225-04-M253&SVSVSI=583&DID=11703 Other interchange formats 91154122503 91154122500 911 541 225 03 911 541 225 04
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 12-15-2022 at 02:24 PM.. |
Hey Isby, how did the aluminum trim fit-up into the seal? All good? Your photo/comments just address the seal alone. Also, I am sending a PM on your glass guys (I am local to you and can use a good resource).
Thanks.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Hey Lyle- No issues with the trim. It fit nicely in the seal. I used the genuine Porsche trim pieces from our host.
In the interest of full disclosure, getting the windshield in required (a) carefully gluing down the dried, stretched out vinyl so that it was tight against the back of the pinch weld all the way around; and (b) replacing the upper part of the dash. The old dash had warped just enough to prevent the windshield from seating properly. I used the genuine Porsche dash piece, which was pricey. My glass guys said that some of the aftermarket dash pieces will cause problems with the windshield install.
Just adding a +1 but for the Rear window seal. Just did one on my car and it worked a treat!
New batch
I was wondering if our host has the new batch in stock? I would like to try the thinner moveable seals for my project. (901 543 901 20 and 901 543 902 20) Thanks in advance.
Here's a thread about the seals: http://forums.pelicanparts.com/porsche-911-technical-forum/1042135-quarter-window-seals-too-tight.html
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 |
Since we seem to have drifted from the windshield to the quarter windows, I'm going to take us back towards the front.
Seems like Uro has been making updates to their rubber seals - both in design and the rubber itself. Is this also true of the rubber seals for the movable front vent windows? These are very, very expensive ($80 each from Uro, or $180 each from Porsche). Any updates to the Uro parts here? Thanks, Mark
1979 911SC Targa |
Hi guys, warehouse inventory update: we have about (120) of Windshield Seal 911 541 225 03 / 91154122503 (which cross-references to 911 541 225 00 / 91154122500 and 911 541 225 04 / 91154122504).
Get them while you can, could be a while before we have more.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 01-17-2023 at 10:55 AM.. |
I ordered the new URO front windshield seal for my 73 and it fit PERFECTLY! I had previously tried the Porsche seal and I couldn't get it to seat. My son and I installed the URO in about 45 minutes.
Hi everyone, we're getting closer on having Windshield Seal 911 541 225 03 / 911 541 225 04 available again (ETA is six to nine months), thanks for your patience. Technically this will be a new version of the seal, but it should be very similar to the highly regarded last version.
Tags: 91154122503, 91154122504
Do you offer 964 front or back seals? I'm just about to try retrofitting 964 front (and rear) glass to my 1989 3.2, that missed the factory change to 964 glass & seals by ~75 cars. Have 964 F&R glass in hand.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
URO parts,
Just wondering how you guys go about verifying quality of the particular rubber compound being used in your products. I know you have had issues in the past, but what many people don't understand is that many vendors are having durability issues with new compounds of rubber. |
That's a good question. On my old '68 Volkswagen I replaced the rubber window seals and within a couple of years the rubber started cracking in the corners. Not saying that will happen with the new URO seals but I wish I'd stayed with genuine seals at the time.
Kurt |
