DerkPerk's Avatar
That tail is hinting at this car being an SC Weissach. Any confirmation?
Old 03-01-2023, 03:45 PM
Unfortunately no, not a Weissach Edition. Somewhere in its life, the tail was put on.
Old 03-01-2023, 04:11 PM
Finally at the body shop. Pretty excited to make some progress. First step after the hood and front fenders come off will be the sunroof delete. We will drill out every factory spot weld and remove the entire assembly.
Old 03-02-2023, 09:40 AM
Flojo's Avatar
as one needs the grinder at the end to skim the edgey anyway I opted directly for the grinder an cut it out. it was done in 15 minutes, including the tabs.
be careful, the roof skin is then very wobly and needs stiffening asap!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-03-2023, 04:43 AM
Yeh, there was no need to go through all the trouble of drilling spot welds.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 03-03-2023, 06:35 AM
Here are some photos of the sunroof plug installed. We decided to bond it in with some sort of state of the art glue. The roof sure stiffened up.
Old 03-03-2023, 10:42 AM
Looks like a great project. I have just embarked on a 78SC in Australia. I see that you are deleting the sunroof, would you be interested in selling some of the hardware that I am looking for?
Old 03-04-2023, 12:11 PM
Yes. Happy to. PM with what you need
Old 03-04-2023, 12:13 PM
Thanks PM sent via email. I hope it worked I am new to using this forum.
Old 03-04-2023, 06:14 PM
I also have some spare sunroof parts if there are additional ones needed.
Nice looking build you have going here! Body work is so gratifying, especially once you see a panel get worked out and smoothed, primed, and sanded to 220 plus. It's art!
GLWTB (Build)!!
Old 03-05-2023, 10:29 AM
Thanks, I will PM you. Hopefully AGCGM has the parts I need. If you have them available that would be great, as long as you are happy to send them to me in Australia, at my expense.
Old 03-05-2023, 11:52 AM
We also removed the sunroof drain tubes for a clean look.
Old 03-05-2023, 08:52 PM
A few weekends ago, my friend Sam and I went out to see Gary Emory at Parts Obsolete
In McMinnville.
I’m going to backdate the dash and also convert the rear windows to pop outs. He has so much treasure!
Old 03-05-2023, 09:10 PM
What will you do with all these turbofans?
Old 03-06-2023, 07:37 AM
PCA Member since 1988
Garage ceiling art.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-06-2023, 02:49 PM
I’m not planning to run coilovers but I thought this would be a smart upgrade anyway. Elephant Racing rear strut tower reinforcement kit.
Old 03-06-2023, 03:34 PM
That's a nice upgrade no matter what. Are you also planning do add their rear spring plate mounting point reinforcements? Another good "While your in there..." upgrade.
Old 03-06-2023, 04:00 PM
Yep, that's a must. Already got the parts.
Old 03-06-2023, 04:21 PM
Working on the rear end backdate. Tail light support brackets changed. We found some interesting lead work on the left rear. It appears that the left quarter panel was replaced at some point too.
Making progress.
Old 03-07-2023, 10:57 AM
New tail light support bracket
Old 03-07-2023, 11:03 AM
