Dual AFR - I wasn't a believer
I've had a long (not really steep) learning curve getting better at EFI - wiring, component selection, ECU issues, injector issues, etc. One of those issues was the use of Innovate LC-2 02 controllers.
I used one controller for the first couple of years and it worked fine....when it was on, but sometimes it wouldn't cycle on and could never tell without having my laptop with me - and on. I didn't want a large gauge on the dash and I didn't want to lose my clock, at the time, so I kept, passively, looking for a gauge solution that would simply help me know the the 02 controller was on and working.
In the mean time, I decided to go to dual 02 sensors (switched to AEM) because I "thought" that I had an issue with an injector that I couldn't diagnose. I was wrong about the injector, but I did get the two 02 controllers installed and started to experiment with tuning.
I also found a gauge, enter Zada-Tech. They didn't have a dual AFR at first, but they quickly whipped one out and within a couple of weeks I was displaying both AFRs in the dash. https://zada-tech.com/products/oled-multi-gauges/oled-digital-dual-afr-air-fuel-ratio-multi-gauge This gauge allowed me to tie straight into the 0~5v output of the 02 sensors and because of the small form factor, I was able to design/print a small bezel that allowed me to put it right in the dash in place of the existing Seat Belt light (super useful).
Back to tuning... I've spent many a minute bent over ITBs trying to sync side to side at idle and also side to side at some random RPM that I would use vise grips to hold the throttle open to achieve. I've used the handy dandy carburetor sync tool, I've used a cluster of vacuum gauges ported to the manifolds, and I've used my ear. This all works fine at idle, but doing this under load sucks and under load is ALWAYS different than at idle due to any linkage slop (they all have some amount of slop).
So, not any more. I learned I could use the AFR from bank to bank to quickly sync at idle and then log data to tune off idle. I switched the sensors from side to side to confirm calibration - just to double check.
While, it's not perfect, and nothing is, it is SUCH a game change for syncing these cantankerous wonders of EFI.
Here you can see the result. Again, not perfect, as there are other things to tweak (AE), but it sure helped.
Back to Zada Tech, this has been a HUGE benefit, as well. Now I can quickly see that both controllers are on and working and I can quickly check to see if the banks are sync'd and that there are no major injector faults causing AFR issues. And it pretty stealthy in the dash.
Happy Days on the AFR front....
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 07-12-2023, 12:54 PM
Great
Old 07-12-2023, 12:55 PM
Bingo
I'm not picking my nose..I'm porting my upper intake manifold.
Old 07-12-2023, 01:21 PM
Slow old car
Maybe not *perfect* but that looks great- nice work
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 07-12-2023, 08:33 PM
PCA Member since 1988
Thanks for the info. I debated with myself whether to get a single AFR gauge (AEM) or a double gauge (Innovate). Since I run CIS, and expect the right and left bank to be pretty much the same (I don't have to synchronize linkages), I decided to use the single gauge with the señder installed in the left exhaust. However, I still can see tat having sensors on both sides could help with troubleshooting misses or roughness. I'm kinda wishing that I went with the dual setup.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-13-2023, 05:56 PM
I didn't think it was necessary, at all, until I started having some issues that I could not diagnose. I had no good/easy way to sanity check what was going on without pulling the injectors and squirting them in a jar. That sucked!
With two 02 sensors, I thought I could at least see that the banks were operating and that I could identify a stuck injector or a non-working injector. Once I had them in place, it turned into a syncing tool. Now I can quickly see, at least, what's going on with each bank.
I use the left bank for control and only monitor the right bank.
'81 911 SC
'03 BMW M3 (Sold)
Old 07-14-2023, 07:11 AM
JackkTheMackk's Avatar
Looks clean. I’m running my innovate in the same spot.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
‘90 OM606 Swapped SWB 300GD
IG: @JackSchroederCreative
Old 07-14-2023, 10:45 AM
Wait.... that's my dash!
'81 911 SC
'03 BMW M3 (Sold)
Old 07-14-2023, 10:47 AM
