Racer
winders's Avatar
Drive-By-Wire Solutions
I upgraded the ITBs for my race car (AT Power) and needed a Drive-By-Wire (DBW) setup. AT Power have a DBW solution using a single servo but, for whatever reason, it would not work properly with the MoTec M150 ECU I am using.
So, I had to look for other solutions. My tuner recommend I try a Bosch-based solution from EFI Hardware in Australia. He also said that he preferred a servo for each bank instead of a single servo setup. I had to design and make the mounting system and modify the linkage arms so that each bank behaved the same.
Here is the result:
The aluminum plate the servos are mounted to is .250" thick. It is mounted to a JB Racing breather cover with a AN-16 fitting. I used two dowel pins to locate the mounting plate on the cover.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 07-19-2023, 09:26 PM
Uncertifiable!!!
Uwon's Avatar
Any pics of the accelerator pedal end?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 07-20-2023, 04:31 AM
This looks pretty slick. What's the cost is associated with this setup?
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-20-2023, 05:12 AM
safe's Avatar
I like! I want it!
Do you have a TPS on each bank or is there a TPS in each servo so the ECU can keep them synchronized?
Magnus
Old 07-20-2023, 07:33 AM
Racer
winders's Avatar
Johan
Scott Winders
PCA GT3 #3
Old 07-20-2023, 08:38 AM
Racer
winders's Avatar
Well, you need an ECU that supports dual DBW servos.
The EFI Hardware servos cost about $725 each:
https://www.efihardware.com/products/3196/drive-by-wire-actuator-dbw
The linkage rods cost something as does the wiring and then you have to set up a PID for them in the ECU configuration. That is best done by a pro.
Scott Winders
PCA GT3 #3
Old 07-20-2023, 08:43 AM
Racer
winders's Avatar
Originally Posted by safe View Post
I like! I want it!
Each EFI Hardware servo has two TPS. One for "main" and another for "tracking". So there are 4 total in the setup. Then you have "main" and "tracking" position sensors for the throttle pedal.
It seems that the consensus these days is that it is better to have the position sensors on the servo(s) than on the ITBs. This is assuming the ITBs have strong enough return spring to close the ITBs if there is a sensor issue. This eliminates any free play issues you might have with the ITB linkage.
Scott Winders
PCA GT3 #3
Old 07-20-2023, 08:49 AM
PCA Member since 1988
Nice work. Please let us know how well it works on the track.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-20-2023, 01:13 PM
So where is your pedal sensor looks like you still have the cable ?
Old 07-20-2023, 07:18 PM
Racer
winders's Avatar
That was a photo from last year. Here is a newer photo:
You can see the green Variohm TPS.
Scott Winders
PCA GT3 #3
Old 07-20-2023, 07:43 PM
Tom '74 911's Avatar
Scott,
That's super cool and interesting, what you're doing. I'm interested to hear how it feels on the track, especially how it compares to your previous setup. Kind of apples to oranges, but my daily driver VW Golf R is drive-by-wire and there are some funny things about it... how the throttle pedal feels sometimes, how responsive it is etc... It probably has a lot to do with the ECU and how it's programed - one funny thing is that you can't be on the throttle and brake at the same time. If you brush the brakes and don't lift off the throttle, the ECU automatically cuts the throttle, and there's a lag before it picks up again when you get off the brakes. Anyway, lots of tuning options likely available... I'm interested to hear about how it feels and how much fiddling it takes to work it out.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 07-20-2023, 08:03 PM
Racer
winders's Avatar
Tom,
The MoTec M150 handles drive by wire far differently than a street car ECU would. From what I understand, the DBW setup is as fast responding to throttle input as a cable setup is. I can left foot brake and be on the gas and the brake at the same time. I can change the progressiveness of the throttle in software.
Cold start issues are a thing of the past. You just start the car and walk away. Rev limiting is much smoother.
Scott Winders
PCA GT3 #3
Old 07-20-2023, 08:16 PM
I figured your system would likely be worked out to 10/10! Sounds like it should be awesome.
Old 07-20-2023, 08:41 PM
DIY wrencher
That's a very trick setup with dual DBW ITBs Scott, and clean install! Does your Motec M150 handle dual DBW stock, or did you have have to upgrade the software?
(Homebuilt by) Jeff also converted his ITBs to DBW, although he used a BMW (S54?) servo to do it.
I've been thinking about doing the same on a 3.6 build, to get rid of the Motronic with the messy idle speed valve setup etc.. With a single throttle body the conversion should be rather easy, you can get a Bosch E-TB for $200 that will bolt right on, and then you can use a 997 gas pedal with the brackets from Adapt Motorsport that also bolts right in.
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 07-24-2023, 09:00 AM
Racer
winders's Avatar
Lukas,
Yes, all firmware versions support two DBW servos. The M130 does too but using two uses a lot of the power available. I am using the MoTec USA Sportscar package.
Yes, a single TB setup is much easier to deal with. These Bosch units are great:
In fact, the EFI Hardware servos I am using are based off that Bosch motor. They just make a custom housing with a different shaft setup.
Scott
Scott Winders
PCA GT3 #3
Old 07-24-2023, 09:34 AM
Originally Posted by Tom '74 911 View Post
Scott,
Tom
Yep that brake override is a safety thing so that the car will stop when someone panics and hits both pedals at once. A lot of manufacturers added that during the whole Toyota unintended acceleration scare, when they found out that it was just old people hitting the wrong pedal.
The rest of it, though, the lack of instantaneous response, is for emissions. Rapid throttle changes are bad for controlling fuel mix so they get smoothed out. If you have a manual they'll also mute the throttle during shifts so you don't destroy the clutch.
I hate those things. A lot. If they're mapped for linear response, though, they can be absolutely fantastic, so very cool to see this work!
1982 911SC
Old 07-24-2023, 10:31 AM
I finally finished my pedal box and dual master cylinder setup, with hydraulic clutch and drive-by-wire throttle. I used the factory pedal box and welded a few pieces of sheet metal to it to adapt a nissan 350z accelerator pedal position sensor. It all fits under the factory floor board and carpet. I wanted "stock appearing" and that's exactly what I got.
https://forums.pelicanparts.com/porsche-911-technical-forum/1160332-early-911-930-pedal-box-scrs-style-dbw-g50-clutch.html
Old 04-16-2024, 08:36 AM
