Can someone tell me what this ground wire is supposed to look like?
it is janky looking, it looks like my distributor ground and there is one on top by the coil that is still mounted, and one I took off by the distributor base. is there a correct way to route this? any pics please would help
1974 911s 2.7
Old 09-05-2023, 05:01 PM
The number one electrical problem of our beloved 911s is poor grounds. That one looks bad. Strip the insulation back and get a solid connection, and use a new lug, and clean the bolt and connecting surfaces.
One truism is very accurate, it is impossible to have "too good" of a ground. More is always better.
Old 09-06-2023, 06:55 AM
ROW '78 911 Targa
timmy2's Avatar
It is the coax shield for the coil and points signal wires. They get grounded to the coil base and by the distributor.
It is “janky” looking for sure, but if they have continuity to the ground tab connector at the CDI they are working.
Porsche used that style of coax for the 3 pin CDI wiring from the 73.5 up to the 77.
Then they went to the 6 pin CDI.
The earlier CDI harnesses that were run separately in earlier years was much more robust.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-06-2023, 08:16 AM
