Bracket available ?
This bracket is cracked, and I wonder if is available, or does it have to be repaired ?
It is the bracket for the Rollbar
Old 07-09-2024, 09:32 AM
HarryD's Avatar
Our host has a number of options to replace this bracket. The WEVO is the preferred choice.
https://www.pelicanparts.com/search/?q=sway+bar+bracket
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-09-2024, 09:36 AM
Banned
Is this from a pre-purchase inspection? If it's your car just remove the whole thing until the bracket is fixed, do not just zip-tie it and keep on keepin' on.
Old 07-09-2024, 10:32 AM
Thank you HarryD - is this the correct part ? What I am looking for, is the bodypart that the sway bar is attached to
https://www.pelicanparts.com/More_Info/91150118000GRV.htm?pn=911-501-180-00-GRV-OEM&bc=c&SVSVSI=
@David - the metal zip-tie was just to get the car home ��
Old 07-09-2024, 11:50 AM
Send a message via AIM to fintstone
It is a pretty common issue. You can replace the part as noted...but you will need to have it welded on. Many prefer the stronger WEVO replacement (as Harry noted) so the repair is not needed again:
https://www.pelicanparts.com/More_Info/WVORARB.htm?pn=WVO-RARB&bc=c&SVSVSI=0569
The clamp looks like it is damaged as well.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-09-2024, 12:04 PM
