85 tire Jack problem
Hi, a while back I was using my factory tire jack on my 85 911 but car moved and Jack got tweaked and now will not crank. Is there a suitable substitute I can buy and carry in my car that would work? Thanks? Nick.
Old 08-29-2024, 05:03 PM
Still here
pmax's Avatar
Always chock the opposite wheel when jacking.
Stay safe.
Old 08-29-2024, 11:07 PM
I carry a 944 alum scissor jack and a 1 ft sq piece of plywood for a base in the '88. Use it on the 4 jacking points. Got it from dC auto. He had a bunch. If you go this route be sure the crank handle is included. Emerg brake on, in gear, and chock if available.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-30-2024, 07:00 AM
I fixed the Jack. Heavy lube and kept working it. Back in car. I’m glad because they are impossible to find.
Old 08-30-2024, 10:02 AM
I have a farm jack that I use for utility rather than vehicle lifting, different mechanism but the manual states to keep it well lubricated. That said, I’ve yet to employ my 911 jack, but I expect it never had been cleaned, lube or used in 45 years.
I like the benefits of a scissor jack but they have equal limitations that can twist when the car inadvertently moves on uneven pavement, but sometimes it can be positioned to accommodate. Base pad and chocks - yes.
Can’t rely sole on trans and handbrake. I keep these (treated lumber is stronger) tucked in front, lodged into the spare tire….
Old 08-30-2024, 10:34 AM
