2,7 liter 1976
engine seized
In neutral I can move the car without problem
with gear in 4th I can rock the car a little bit ,the ventilator moves about 2 mm to and fro . When I try to turn the motor with a wrench it s totally stuck The motor is standing for about 5 years now after the PO said a rebuilt ,there s no oil in it I pulled the plugs, there new, not used Now trying to remove the starter motor but struggling with upper nut Can I use a breaker bar to put some more strenght on the wrench? |
Do not use a breaker bar to turn over the engine! Something is seized and you will break it.
Time to drop the engine for a proper inspection. |
Behind the Sun
If you trust the previous owner and you know for sure that was rebuilt and in good order.
1. Take all 6 spark plugs. 2. Put a mix of brake fluid and power steering fluid (red) down the cylinders 3. Leave the mix for a few days if not a week. 4. Put a socket in the crank bolt and start rotating gently. If the the engine was good to begin it should loosen If there is something really locked it's time to take it apart |
Take the engine out. Leave the starter in. There is no easy way out of a stuck frozen motor.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
2,7 liter 1976
I can try it at least
I remember when I bought the car engine was free. I just mounted cis carefully looking nothing fell into the intakes. I can turn the nut about 5 mm each direction... |
It's a 914 ...
Put a scope through the sparkplug hole to see what’s up in your cylinders.
Is there a chance a cylinder filled with fuel during an extended fuel pump run? Leaky injector or carb overflow. It can happen. In case this is suspected, definitely don’t try to turn the engine over. It can bend a connecting rod or damage a piston. If it’s just light rust on cylinders, it’s worth trying Marvels, ATF, etc as suggested to see if you can loosen it up. Nothing to lose if the only other option is opening the motor up. |
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Behind the Sun
2,7 liter 1976
i can turn a bit and then it s like it is held by something
Pitty I can t upload a video. If it was a cilinder/piston problem would I be able too moove the nut at all? |
2,7 liter 1976
Oh yes, plugs and starter are removed,could the dizzy block it?
Behind the Sun
Now you got me thinking remove the fan belt. I had a 911 once where the pressure plate cracked, the took the reference sensor too. That car was locked. But it was a running track car. Not your sitting car. |
Counterclockwise?
Why is there no oil in it?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
It's a 914 ...
For reference, I once had a 968 race engine (iron sleeve cylinders) that would turn over a little in either direction and just stop when the piston/rings ran into the ring of rust that had formed in the cylinder when the engine sat for several years.
Just a note, only turn the engine clockwise, you can skip timing going counter clockwise.
Rutager West 1977 911S Targa Chocolate Brown |
2,7 liter 1976
PO rebuilt engine and never put oil in it.Nor did I.I m gonna buy the MMO and try,hopefully it s the ring of rust in the cilinders.
Thanks all |
![]() If your not going to remove the Engine, you should at least remove the chain cases to make sure there are no issues with the chain, guides and tensioners, a problem here could be related to why the engine will not turn! Just a thought, also; if the engine has never had any oil in it, there could be several surface parts where rust has accumulated, i.e.; cam bearings, crank, intermediate shafts etc, again; all potentials why it wont turn. Hope this helps. Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 11-07-2024 at 01:52 AM.. |
If you can't find MMO, put some confit de canard and graisse d'oie, and add a glass of Floc de Gascogne. You seem to be in the right place.
Gilles RoW 88 Carrera coupé |
2,7 liter 1976
If I can t get that thing turning I ll need a whole boytle of Floc I m afraid...
Good thing about the chain covers,they come off eith engine in the car? |
