Stud Stripped its Hole
It's not my fault! Ok, maybe it is. But that's not the point.
I tried to put on a nut, and it started spinning its stud before hitting the torque spec (18 lb/ft). Then I tried remove the nut, and it is still just spinning its stud. The nut does not move further out, it spins the stud along with it, and I can't seem to work it free with lock pliers. Now I have a chain housing attached with a nut that can't tighten and won't back off/out either. How do I remove the nut, and/or extract this stud from its stripped hole? And how do I move forward afterwards?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
PCA Member since 1988
Keep turning it, and pull outwards as you do. It will eventually come out. Then Timesert/Helicoil the stripped hole and reinstall. And make damn sure your torque wrench is accurate. 18 Ft-lb is the upper spec. For M8 nuts/studs/bolts, the usual spec range is 15-18.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Navin Johnson
Is that a lock nut?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Got a welder ?
All of the things that I can think of end up with the likely use of a welder to extend the stud so it can be worked out. The working out portion may involve making a little puller tool. Once the stud is out, the messed up threads /hole will end up with an insert. I had a 2.7 mag case with basically every threaded hole fitted with an insert. It just got to the point where it made sense to do that ahead of assembly so I didn’t have the stress of worrying about a fastener making it to torque. I’m curious what gets suggested and how you eventually solve this problem. |
Maybe part of the issue is how I interpreted Wayne's book "Use the factory 13mm nuts on the studs... [that] are egg-shaped locknuts that resist vibration." I used prevailing torque nuts here. I put one on and torqued it originally without issues. Then took it off to redo a chain route. Then I put a fresh one on. I did not pass the torque spec, however, it stripped before I hit the torque. So maybe I'm not to blame?
I don't see any inserts on PP except for head studs. Any recommendations for a little m8 like this?
I couldn't find anything on our host.
Maybe something like this? https://www.mcmaster.com/90025A113/
Found the Time-Sert site, looks like that is the gold standard.
I guess I need to get the stud out and figure out what is the appropriate depth. Yay!
Yes, use time-serts. Depth for an M8 stud is 16mm.
Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair |
Maybe the nut threads stripped and not the stud. Wrong nut anyways. Use a normal nut.
Grab the nut with a small channel locks or pliers. Pull back on the nut as you turn it counter-clockwise. The striped threads just need a little help coming out.
Otherwise use a Dremel & cut a slot in the stud for a screwdriver. Hold the stud, spin the nut. |
i would use butane torch heat it up should come off, after inspect and use only regular nut and wave washer not spring and not locking nut
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
To OsoMoore, I called Pelican to get the right stud and they gave me part number 99906207302, which is an M8x16. The PET calls out an M8x20, but best to check once you have the stud out. Yours looks like mine, though, where the threads don't stick out past the end of the nut.
1982 911SC |
Given the proposed 16 mm "depth", I summarize the entire stud should be 35 or 40 mm in length. I'm going to wait to order the Time-sert kit until I actually get the stud out, and didn't have time to work at it this morning.
According to the PET, the correct stud in that position is M8 x 20mm. Porsche followed the DIN 835 standard for the studs, so 20mm is the nominal length and the total length is 36mm. The part number 99906207302 is not correct. You can use part number 99906200603, but it is 1mm longer at 37mm. Belmetric carries the correct DIN 835 length stud if it matters.
See my post below for more information... Quote:
Meanwhile I have plenty of small things to clean while I wait for shipping.
It was NOT the hole that stripped, but rather the end of the stud. Probably torn up one two many times by my re-applying of that nasty nut.
Its neighbor also seems to be damaged, so I suspect I should replace both. What's the preferred way to get these guys out? Double nut and push hard? Pick up a torch at HF and apply some heat first? ![]()
use heat and just clean up the upper threads ,do not go to crazy about the 18pounds 16 is just fine
Ivan
A stud extractor worked fine for me with a bit of heat. The style that's a three-prong gripper in a chuck.
I'm happy to be wrong about the part number, but the 99906207302 stud was what I was given to over the phone from pelican and it matched existing. To be fair they said they weren't 100% certain themselves. YMMV.
1982 911SC Last edited by David Inc.; 10-21-2025 at 10:46 AM.. |
After hanging around aircool engines for years, I broke down and got a set of Stud Extractors Collets. That would make this an easy job.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
