Bravo's Avatar
930S Steering Wheel Spacer
I am getting ready to order a 930S wheel from Pelican for my 78SC and was wonderin if you guys are also buying the spacer to put the wheel slightly closer to the driver? Is it necessary or is it just more comfortable?
Dean
1978 SC Targa Euro
1966 911 Coupe Restored/Burned/Sold - In that Order
Old 11-28-2003, 06:09 PM
Dean, I did not need the spacer when I installed the 930S wheel in my 80SC. The wheel is one of my favorite upgrades! Craig
80SC
Old 11-28-2003, 06:58 PM
89turbocabmike's Avatar
Dean, I would recommend the spacer. Everyone recommended it to me. When I ordered my wheel from PP, they forgot to send the spacer! Of course I couldn't wait to install the wheel, took all of 30 minutes(some of that spent ranting about the missing spacer). The wheel was a bit close to the dash, but livable, but the inability to see the speedo above 60 was a bit un-nerving. I like to know just how much I breaking the law The spacer will make this an all around perfect upgrade. This wheel is awesome.
Old 11-28-2003, 07:01 PM
I got the spacer and wish it was bigger. It's smaller than the factory spacer, and that was almost enough.
Old 11-28-2003, 07:02 PM
jyl jyl is online now
jyl's Avatar
There's been some earlier posts with pictures of the wheel-to-dash clearance with and without spacer.
The spacer also makes the wheel eccentric, which some like and others don't. I like it as there's more legroom at 6 o'clock and more leverage (e.g. for parking) at 12 o'clock.
Old 11-28-2003, 07:04 PM
moazam's Avatar
Send a message via AIM to moazam
I didn't need the spacer. As for the speedometer being blocked by the steering wheel, I just rotated the gauge 90 degrees to the left.
2014 Porsche Cayman S
2001 BMW 525i Touring
1996 Porsche 911 (Gone to Germany)
'86 911 Carrera (Gone to Aruba)
Old 11-28-2003, 07:30 PM
Mark Wilson
Guest
Posts: n/a
Got spacer, installed spacer, hated spacer, removed spacer, love 930s wheel. The spacer cocked the wheel up at a weird angle. Also, it made the wheel rotate in ovals rather than circles. There's plenty of oom between dash and wheel without the spacer in my car so no needy.
Old 11-28-2003, 08:04 PM
Adman's Avatar
Send a message via AIM to Adman
Just goes to show how 911 interiors vary. If I had not used the spacer on my install there would have been less than 1/2" clearance between the dash pad and steering wheel. Wasnt an option for me
Matthew D.
'87 Carrera Coupe
Guards Red/Cold A/C
PCA Member
Old 11-28-2003, 08:45 PM
Bravo's Avatar
Well there is definetly some differences of opinion out there and thanks for the inpu. I dont really like the idea of the wheel moving oval. I will most likely not get the spacer and try it. thanks for all of the replies. I can see this is a great upgrade.
Dean
1978 SC Targa Euro
Old 11-29-2003, 08:21 AM
Todd Simpson's Avatar
The stock wheel does this too, to give more legroom.
A smaller wheel spaced to come closer to you is a big upgrade if you're taller, IMO. I've got a 350mm Momo, but the 930S has a nicer "Porsche" look.
Old 11-29-2003, 09:13 AM
Canadian Member
911Rob's Avatar
I used the spacer on my 74; love it. Without the spacer the wheel would definately be too close to the dash for my liking.
To space or not to space; now this is the question............
Space a 78.
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 11-29-2003, 10:15 AM
FWIW, I drive my car every day. I know from the shape of the spacer that the steering wheel moves in an oval arc, but I certainly don't notice it. Worse case scenario.....another call to Pelican! Enjoy the wheel
Old 11-29-2003, 10:20 AM
Administrator
Jack Olsen's Avatar
I prefer the off-center movement of the wheel with the spacer. At least in high-intensity driving, it provides feedback on where the wheel is in its rotation without needing to look down.
Being able to see the gauges and having more room for your legs when you get into the seat are bonuses, as well.
Old 11-29-2003, 01:31 PM
MuffinMan's Avatar
Jack, do you shuffle steer? If so, I can see your point in terms of the off-center wheel helping denote the position of the wheel/tires. If a driver is not a shuffle-steerer, his/her hand position should tell them where the front wheels are pointing.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 11-29-2003, 03:08 PM
