Paulbav's Avatar
Question Bleeding hell!!
Can somebody please help me I've just fitted new discs pads and ss hoses on my 89 3.2 but can't seem to get any pressure when i press the pedal!. I'm using racing blue fluid and have bled from all corners in the right order untill no more air has come out but still nothing! it has taken about 1 and a half litres of fluid now. Am i missing some thing?
Ta paul
1990 944S2
(Gone to a new home)
1989 911 3.2 Carrera sport
slate grey
Old 05-02-2004, 08:13 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Did you press the pistins all the way in to get the new pads in? That might be your problem. The proper way is to push them in only far enough that you have a hard time to get the pads in. Almost like an interference fit. Pump each piston out without the pad installed, push it back carfully and wedge the pad back in. That should give you a rock solid padle.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-02-2004, 08:21 AM
Paulbav's Avatar
Hmmm pad were a tight fit when i fitted them and I can't pump them out as the pedal just goes straight to the floor yet it pumps the fluid through when the bleed valve is open!
1990 944S2
slate grey
Old 05-02-2004, 08:25 AM
What Ingo said. If you pump the pedal do they eventually get hard?
Old 05-02-2004, 08:26 AM
Par911's Avatar
Frozen calipers? Try to pry the pistons out further with a screwdriver.
Old 05-02-2004, 08:35 AM
Paulbav's Avatar
if it were the calipers frozen would i not still have pressure at the pedal just inefective brakes??
1990 944S2
slate grey
Old 05-02-2004, 08:40 AM
Par911's Avatar
It depends, usually you would still have some pressure. Just to make sure they aren't frozen get someone to look at the pistons while you depress the brake pedal. If the pistons move then its probably not a frozen caliper problem.
What Ingo said, the loss of pressure could be caused because your pistons are pushed too far. Make sure there is no space between your pistons, and brake pads. It should be a little difficult to put the new pads in, that's how tight the fit should be.
Did you try pumping the brake pedal with the pads out as Ingo suggested?
Old 05-02-2004, 09:38 AM
Paulbav's Avatar
I'm doing this on my own so hard to see the calipers while pressing the pedal, but if i really pump the pedal it does get some pressure and if I move the car it will stop when pressing the pedal just not any where near as good as it should!! so I guess that the calipers are moving??
Paul
1990 944S2
slate grey
Old 05-02-2004, 03:14 PM
cyprusx's Avatar
You can't pedal bleed the brakes by yourself. You have someone pump 5-7 times and on the last pump, hold the brake pedal to the floor and close the bleeder while the pedal is on the floor. Repeat for each corner and you will be good to go....
Rick
88 Carrera Targa
-- There are only those that know and those that do not!!! --
Old 05-02-2004, 03:23 PM
Paulbav's Avatar
I have non return valves on the nipples and a friendy lump of wood to hold the pedal down normaly works fine! but not this time.
Paul
1990 944S2
slate grey
Old 05-02-2004, 03:25 PM
Jim Smolka's Avatar
Bleed the rear brakes. Then put the old pads back in the calipers. Bleed system. See if the old pads close on the rotor. Remove old pads and see if the new pads will allow the system to bleed.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 05-02-2004, 04:49 PM
Steve W's Avatar
Air in the master cylinder? You could be pumping your own air in there back and forth.
Old 05-02-2004, 05:47 PM
ischmitz's Avatar
Why don't you get a friendly neighbor to help. I think it'll be very hard to get the bleeding right with just one person and the wood block method.
Cheers,
Ingo
Old 05-02-2004, 05:49 PM
350HP930's Avatar
Your one man bleeding operation is your problem.
+1 on getting someone to help you.
Even if you have return valves on the bleed nipples air can still be drawn back in through the bleed screw threads.
Old 05-02-2004, 06:02 PM
Formerly bb80sc
Vipergrün's Avatar
The only way you can pedal bleed the brakes yourself is if you have Speed Bleeders installes in place of the original bleeder screws. These allow fluid out, but no air in. In your case, you MUST close the bleeder screw whilst fluid is coming out..... BTW, I have Speed Bleeders and they are absolutely terrific...
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 05-02-2004, 06:28 PM
Early_S_Man's Avatar
Porsche Crest
You don't need speed bleeders or pressure-crap-hardware to bleed brakes by yourself!!! Some of you guys don't have ANY imagination, and apparently no clue how to improvise! Buy a new gadget seems to be your only modus operandi ...
I've been doing it 35+ years with a section of 2x2 braced against the seat ... never had a problem, yet!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-02-2004, 08:20 PM
David's Avatar
MOTIVE, Motive, motive,........................
Old 05-02-2004, 08:38 PM
Hey , I had the same problem some weeks ago , and after checking the manual, I've found out that you should not use the "pedal system" , but have to use a "bendix" system where you put airpressure in the oiltank.
Did this (in a friend garage) and all problems where solved right away.
maybe it's this ?
bye
Old 05-03-2004, 02:22 AM
Jim Smolka's Avatar
Warren,
Don't be letting that information getting around. Having a buddy come over to help bleed brakes is a great reason to consume a couple of cold ones...
'81 SC 3.6 (Beast)
Old 05-03-2004, 02:57 AM
Paulbav's Avatar
Ok I have had my dad round to help me this morning but still no joy, the calipers are not stuck or frozen as I can see them out and pushing the pads against the discs and if I really pump the brekes I do get pressure but as soon as I let off the Pressure goes! we bled the whole system again several times and there is no more air coming out. Is it possible that there is air in the master cylinder? and that I am just pushing it around the system and never getting it out??, I think that I'm getting to the stage of giving up now and crawling my way down to the local mechanic using the hand brake! as I figure that brakes arn't the best thing not to have faith in my own work!.
Paul
1990 944S2
slate grey
Old 05-03-2004, 04:20 AM
