blasting materials
I recently bought a blasting cabinet, what would you guys suggest i use to clean my heads etc. glass beads maybe? what size?
brian
*NEW 1969 911t targa soft window option 1967 912 Targa Soft Window 1989 911 GP White Cabriolet 1970 911t 2001 Chevy Silverado 1500 1997 Audi A4 Quattro 2.8 2003 Acura TL Type S 1973 911t 3.0 track car (SOLD) |
Stressed Member
Brian-
I use a medium grit glass bead. This is aggressive enough to work without being likely to quickly damage stuff. Be sure to wear a respirator when you use the cabinet, particularly with anything that is cadmium plated. Also, I strongly suggest that you blast outdoors. It makes a mess! -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
Yes, glass beads. Eastwood sells 70-100 grit for this purpose. They recommend no more than 60 psi pressure.
http://www.eastwoodco.com/jump.jsp?itemID=1313&itemType=CATEGORY&path=1%2C2%2C1310&KickerID=243&KICKER
Warren & Ron, may you rest in Peace. |
Blasting media comes on all sorts of forms depending on function, cost, environmental conditions and more. It can vary from glass beads to nut shells to lead or steel shot, to solid CO2 and much more. The important issue is to match the media, technique and subject part to achieve the desired result.
I won’t claim to be an expert but over the years I’ve done a lot of this. This would be a good thread to review all the media, techniques, etc. The four areas I am sort of familiar with are: Stripping of some prior finish. Cleaning of dirt, baked-on grease and corrosion. Preparation for a surface finish (plating or painting), this is different from above. Stress relief (connecting rods). How about some expert input. ![]() Best, Grady |
What would you use to do fuchs?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
im trying to remove old paint for new paint on some parts and powdercoating on others.
nice doggie
I think blasting is a hoot. I'm no expert, but I get a real kick out of doing it.
Jerry 78 SC hotrod 02 Mini Cooper S |
Slippery Slope Victim
It depends on what you are doing to the Fuchs. Are you blasting off anodising or paint and do you want to achieve a finished product from the bead blaster.
Be careful, go slow. Try to use the least abrasive beads that will still get the job done. I've use glass beads on everything, the only thing is varying pressure and using all sorts of glass beads and combinations. Good Luck.have you done a search yet?
Mike² 1985 M491 |
FWIW - I've purchased from these guys and have had good service.
http://www.kramerindustriesonline.com/contact-us.htm Their site is informative regarding what products are available (I didn't know that people blasted with walnut shells!!). Also you can give them a call and talk to them about your application. I did and the fellow there gave me plenty of information on various materials and eventually recommended that I go with "fine" glass beads for what I typically need to do which is remove old paint and light corrosion from mostly aluminum parts.
Gary Osborne Chardon, Ohio ___________ 74 911 IROC 98 Panoz GTWC |
Thread Tools | |
Rate This Thread | |
